woodman Posted December 4, 2017 Posted December 4, 2017 I am looking for a complete engine package for a very basic budget build. ideally with exhaust manifold , inlet , ignition etc. anything considered, - Bike or car engine eg Crossflow, Zetec, K series, VX Early Blade, R1 To suit a narrow chassis Thanks Stu
Martin Aldred - Shows & Events Coordinator Posted December 5, 2017 Posted December 5, 2017 @woodman I am hopefully swapping my pinto out over christmas. It will come out complete with twin 40s electronic ign , westfield alloy sump and bell housing, engine mounts, radiator, stainless steel exhaust system. Â
woodman Posted December 5, 2017 Author Posted December 5, 2017 Thanks for reply Neptune. Do you have a price in mind please Stu
Martin Aldred - Shows & Events Coordinator Posted December 5, 2017 Posted December 5, 2017 8 hours ago, woodman said: Thanks for reply Neptune. Do you have a price in mind please Stu Pm sent
Arm Posted December 6, 2017 Posted December 6, 2017 Complete package 270 bhp Vaux XE. dry sump, exhaust manifold and silencer, throttle bodies, engine loom, pressure reg, alternator, twin plate clutch, steel flywheel, steel crank. 9000 rpm But if you need to ask how much I suspect it may be more than the amount you have in mind  A 1
TAFKARM Posted December 6, 2017 Posted December 6, 2017 On ‎04‎/‎12‎/‎2017 at 22:47, woodman said:  for a very basic budget build.   1 hour ago, Arm said: 270 bhp Vaux XE. dry sump, exhaust manifold and silencer, throttle bodies, engine loom, pressure reg, alternator, twin plate clutch, steel flywheel, steel crank. 9000 rpm     2 1
mark.anson Posted December 6, 2017 Posted December 6, 2017 Probably not what your after but I have a 2012 ex John Trigger Racing Honda 1000rr Fireblade in the garage I could be tempted to sell. Full race spec, ported head etc pretty much what Terry Everall is running at the moment. Fitted with an AB Performance sump however it's a bare engine so you will need throttle bodies, loom, coil sticks air box and a stator, but all easily available from the bay of e or breakers. £2200:00.  Â
woodman Posted December 6, 2017 Author Posted December 6, 2017 Thanks for offers Ash and Mark Both excellant But in this case, as RussH says, I am really looking for something more basic . If the redtop was just a std engine....( just on carbs, etc) if the blade was one of the older types ....( could do with all the bits tho) Stu
Derek182 Posted December 6, 2017 Posted December 6, 2017 And I have a 1.8 Zetec with 2 litre cams on a Raceline sump, could come with twin 45 Webers or standard Ford Injection, alternator, all sensors, coil pack and Weber Alpha ECU and ignition system. Wouldn't have an exhaust manifold as I'm using that on a higher spec Zetec. Would be £600 with Ford injection and standard flywheel, £1000 with the Webers or £1300 with a lightweight flywheel and paddle clutch as well.
woodman Posted December 6, 2017 Author Posted December 6, 2017 Thanks Derek I have been offered a few Zetec packages , All good like yours I will need to compere them as they are all different . Whereabouts in country are you? Â
bioman Posted December 7, 2017 Posted December 7, 2017 Hi, I have a 1.6 CVH engine complete. Twin DCOE 40's, exhaust manifold etc just needs bolting onto a type 9 box. Was in my SE until July this year. Â
John Loudon - Sponsorship Liaison Posted December 7, 2017 Posted December 7, 2017 Stuart. Check eBay item 142597494552 Cheers JohnÂ
