Rover 3.5 V8 engine.
This engine has covered 13,000 miles in a Westfield since 1996. Rebuilt with reground crank, .010 mains and big ends, new timing chain, new water pump, new oil pump. In 2004 a rolling road set up showed 142bhp at the wheels with a DW262 Hurricane camshaft. Complete with all ancilliaries, starter motor, alternator, distributor, twin SU's, clutch, flywheel. No exhaust manifolds.
£400.
Hi @bollockybill.
I'm assuming as it not listed you are not selling a gearbox with this?  What gearbox was it mated to in the car before removal?
Bob
Hi Bob,
Engine and box are standard SD1 fitment. The gearbox is an LT77, I'm hoping to rebuild and reuse it, although if the later R380 came up for sale I may be tempted by that. They use a common casing but a 4wd box needs a lot of parts changing to make it 2wd so is prohibitively expensive.
John.
