The Cheese Posted August 6, 2017 Posted August 6, 2017 hi all looking for help please the westfield i bought came with a detachable steering wheel which i don't like the feel of, as they always feel quite slack with play in ,so i want to change it back to to a bolt on steering wheel which boss kit do i have to buy to be able to put a omp sparco steering wheel on Quote
Dave Eastwood (Gadgetman) Posted August 6, 2017 Posted August 6, 2017 A slack feeling quick release wheel is a symptom of either a poor quality quick release, or wear, or of course a bit of both. Decent quality "ball" type QR hubs have zero slack/play. We need to know how your existing QR hub is fitted, as many of them are welded to the column. If it is, then your easiest solution would be to get an new upper/inner steering column with the splined top still in place. If you are lucky and it's not a weld on QR hub, then it may just be a case of unbolting it, as they normally just bolt to an existing boss. For reference, the standards Westfield splined column on the current cars (and has been for many years), is the BL 48 spline pattern found on many Land Rovers, Minis, Alegros etc. Quote
The Cheese Posted August 6, 2017 Author Posted August 6, 2017 The steering wheel boss comes straight off the spline I will try and get some pics posted Quote
Andy (Sycho) Posted August 6, 2017 Posted August 6, 2017 I used this one https://www.ebay.co.uk/p/1387425825?iid=361290273131&trdt=0&rdtsrc=vi but it all depends how far you want the wheel from you as you can get longer Ones or spacers. Quote
CraigHew Posted August 6, 2017 Posted August 6, 2017 @The Cheese, does either the splines or the inside of the QR boss look worn? Quote
CraigHew Posted August 6, 2017 Posted August 6, 2017 but you can wiggle it and see/feel some play? Quote
CraigHew Posted August 6, 2017 Posted August 6, 2017 it looks similar to mine, which is a Racetech unit. Normally pretty robust...! The link Andy sent you would be fine although clearly you can get slimmer ones. Quote
Dave Eastwood (Gadgetman) Posted August 6, 2017 Posted August 6, 2017 Some play isn't uncommon on those splined type Quick releases. Unfortunately though that splined end is part of the quick release hub - they are supplied with them. You cut the end of the original steering column off, and weld that special splined section on in its place. The spline section normally has a "key" spline to align the QR hub, it also doesn't normally have a threaded end etc. Long and short of it is that it's not a modification that's readily reversed. The easiest way is to buy a new complete in er steering column, I'm afraid. Otherwise, I suppose you could try adapting the one you've already got to a zero play type QR boss. (Would mean getting the column modified a second time though). Quote
The Cheese Posted August 6, 2017 Author Posted August 6, 2017 This was a factory built car with only 5000 miles on clock and steering wheel is not set straight either can it be adjusted to at least be straight Quote
marcusb Posted August 6, 2017 Posted August 6, 2017 check there is no play between upper and lower steering column this could be part of what you are feeling Quote
marcusb Posted August 6, 2017 Posted August 6, 2017 28 minutes ago, CraigHew said: it looks similar to mine, which is a Racetech unit. Normally pretty robust...! same as mine and no play very solid and should be for price! Quote
The Cheese Posted August 6, 2017 Author Posted August 6, 2017 The race tech steering wheel only has 3 bolts through but it's too small for me where can I get another steering wheel prefer 300mm Quote
