Zetec package, gearbox, cooling, exhaust, the lot! SOLD
Zetec engine, gearbox, and cooling system package. Built, tuned and running setup producing 173bhp (graph available). Only 6,000 miles.
Due to major upgrade-itus I planning on selling my complete engine package.
2.0 Blacktop Zetec crate engine which was bought brand new in 2009 (£850 new)
Raceline wetsump kit (£500 new)
Raceline water rail kit (£300 new)
Raceline Cam Cover insert (£60 new)
APR big end bolts (£60 new)
Retro Ford alternator kit for lightweight alternator (£130 new)
Lightweight alternator (£140 new)
Spare coil pack (£40 new)
Westfield engine mounts (~£120 new)
Weber DOCE 45’s and ALPHA GOLD Ignition kit, ecu and loom (~£,500 new)
I also have a lightweight flywheel and custom plate so you can use a remote oil filter next to the engine mount. (£££)
Stainless steel exhaust manifold (£500 new)
Stainless steel 7” custom polished Simpson’s silencer which tests ~96db (£650 new)
MT75 gearbox with Westfield short shift from original factor built car (£150 second hand value)
Polo Radiator with high performance fan and all silicone hose kit and Westfields “race” ducting for use with a normal nose (~£200 new)
Oil catch tank and silicone hoses (~£60)
Build £££
Set-up/Tuning on a rolling road £500
This is everything you need for a rolling chassis or to upgrade from a crossflow, pinto, etc.
The above totals to over £5,760. I’m looking for £2,500.
The package is still in my car so you can come as see it running, go out for a drive, or I can make a video for you.
