Roll bar , exhaust , zetec sump
Wide Rac rollbar used condition rear uprights have some slight marks and have been repowdercoated I should have most if not all of the rosejoints (new) bolts and spacers . Not legal for racing now of course but much safer than the standard hoop . £85 posted SOLD
Tech craft mega flow silencer,  used condition does have a slight dent that has been straightened nicely intake pipe has been rewelded at some point. Bargain at £60 SOLD
Standard Ford alloy Zetec sump suitable for shortening comes with splashguard , rare to find now £50 posted
May be a slight delay in postage due to volume of parts being cleared out
Hello Julian,
Looking for a silencer.
What size is ? inlet size, muffler diameter, muffler lenght ?
Is it repackable ?
Thanks,
Mauro
I'll put sizes up tonight @Mauro I was a bit rushed last night
@Mauro yes silencer can be taken apart and repacked .
End to end is 890mm , silencer sleeve is 650mm and is approximately 6" diameter . Intake pipe is 64mm but an adapter could be probably made easily enough by an exhaust supplier
The silencer suits my needs.
PM sent
Is that a silvertop sump or blacktop?
Silvertop
FWIW the silvertop sump pits the blacktop just fine  (using a silvertop rubber gasket)
Yep my blacktop uses my old Scholar silvertop sump. Just had to use the windage tray that was on the Silvertop. (Which is in the picture too)
Hello there,
Has the silencer sold?
Allan
I still have it but subject to posting to Italy if it does not go you will have second dibs @AllanI
  • 3 weeks later...
Have you still got the roll bar
Hi, Is the RAC roll bar still available?
Thanks,
Rob
Yes @robwalker1 still available , I have found all the bolts and rose joints , just needs two spacers inside the rosejoints , I can probably find where to get them very easily online.
McGill Motorsport does a variety of spacers, they may do them?
