Ford 1.8/2L Zetec Intake manifold/fuel rail/fuel regulator/idle valve/TPS Ford/Westfield air intake
Having recently upgraded to Omex TBs, I have the following parts available which are literally as new as engine had covered 500 miles from new :
Fuel rail with fuel regulator £50
Fuel manifold complete with throttle body £70
Idle valve    £20
Ford TPS     £35
Westfield fiberglass intake with matching XP Pipercross £100
Throttle cable                                                      £5
All plus PP @ cost.
Please see attached pictures (TPS sensor is Omex but FORD OEM is for sale - still on car).
Thanks for looking.
If the throttle cable has a 10mm x 6mm barrel nipple on it then I'll take that from you Mr. Poseidon (can't tell from the photos).  If so, please PM me payment details and I'll let you have my address.  Could you also let me know the length of the inner cable please.
Thanks,
Stuart
Thanks,
Stuart
Hi Stuart .
I'll measure and check it out tomorrow for you and let you know .
Best P
  • 3 weeks later...
Hi Stuart.
The cable has a small ball shaped end ion any good ....
Thanks but I don't think so. I've sorted it now anyway.
  • 4 weeks later...
Bumpy bump.
