Martin Aldred - Shows & Events Coordinator Posted April 23, 2017 Posted April 23, 2017 MCT75 gearbox only covered approx 1500 miles Alloy cased all synchromesh and renowed for being a strong gearbox Std MT75 ratios Input shaft same as 'short' type 9 with 23 splines No Bell housing they can be readily bought from Burton Power, Raceline , RWD motorsport etc.. Also availble is a MCT 75 quickshift seen in the photo attached to the gearbox Collection preferred or can be taken to stonleigh sun or mon £550.00 with quickshift £495.00 without Also propshaft MCT75 to sierra diff . used with above gearbox so only approx 1500 miles £100.00
Greenstreak-Andy D Posted May 5, 2018 Posted May 5, 2018 @neptune I sold my MCT to the owner of Spyder Cars http://www.spydercars.co.uk/ They use the MCT box on their Elan build. Worth a phone call. Think chap was called Tony, but I’m hopeless at remembering names! Alternatively Blat chat or Lotus Elan chat room? http://www.clublotus.co.uk/lotuselan.aspx
Martin Aldred - Shows & Events Coordinator Posted May 5, 2018 Author Posted May 5, 2018 @greenstreak Thank you will get in touch with them
mrsntw Posted April 16, 2019 Posted April 16, 2019 @neptune Complete shot in the dark this, but is the driveshaft still available?
Martin Aldred - Shows & Events Coordinator Posted April 16, 2019 Author Posted April 16, 2019 Yes it is
Pascal_44 Posted June 16, 2019 Posted June 16, 2019 Hi Neptune, Is your MCT75 still available ? Have a nice sunday Pascal
Martin Aldred - Shows & Events Coordinator Posted June 16, 2019 Author Posted June 16, 2019 Hi Pascal , Yes it is
Pascal_44 Posted June 18, 2019 Posted June 18, 2019 Hi Neptune, I have a question about the ratios , do you mean that it's standard MCT75 ratios or standard MT75 ratios ? I understood that MCT75 is an upgrade with a closed ratios 😲 Could you clarify the ratios of the gearbox ? Many thanks in advance
Kingster Posted June 19, 2019 Posted June 19, 2019 The MTC 75 as supplied by Westfield is usually a Mitchell Cotts gearbox and uses the exact same ratios as the MT75 - so no close ratios. I think there is an MTC gearbox made with better ratios but as @neptune states this one has std MT75 ratios, then I’d say it’s not one of those
Martin Aldred - Shows & Events Coordinator Posted June 19, 2019 Author Posted June 19, 2019 14 hours ago, Pascal_44 said: Hi Neptune, I have a question about the ratios , do you mean that it's standard MCT75 ratios or standard MT75 ratios ? I understood that MCT75 is an upgrade with a closed ratios 😲 Could you clarify the ratios of the gearbox ? Many thanks in advance Hi Pascal, This box was originally supplied by Westfield in a factory built car with a duratec engine. Sorry I have no idea what the ratios are. The MT 75 was a gearbox with integrated bell housing as I understand, where as the MCT75 is a gearbox without bell housing. Perhaps someone else would be able to advise ratios.
WillC Posted June 19, 2019 Posted June 19, 2019 HI REF YOUR MT 75 QUICK SHIFT, IS IT AVAILABLE ON ITS OWN? Bill
Martin Aldred - Shows & Events Coordinator Posted June 21, 2019 Author Posted June 21, 2019 Hi Prefer to sell it with the gearbox Thanks
