Paul Aspden Posted March 12, 2017 Share Posted March 12, 2017 711m crossflow engine, ported and chambered big valve head (42 inlet 31 exhaust) roller rockers, forged pistons, steel rods, duplex timing gear with Vernier pulley adjustable without stripping engine! Flywheel and block modified for crank position sensor, cam sensor also fitted. Dry sumped with titan sump pan, remote filter and cooler. Engine approx 1700cc, cam thought to be standard, with steel multi layer head gasket. Supercharger fitted to block, taken from SC mini. Comes with adaptor to 3" diameter tube, some silicon hoses (3") and an intercooler to fit the front of a westfiled chassis (narrow) Jenvey 45dcoe pattern throttle bodies, complete with linkage and turbo cast aluminium air box and air horns. All on a xflow inlet manifold, complete with injectors and throttle position sensor. 4-1 stainless steel exhaust manifold to suit application, this is a lovely piece of work. A fantastic upgrade to a period car, note that all the above would benefit from a stip clean and rebuild as it is as yet unrun, and has been poorly stored by others £2750 Contact via pm or phone 07973 504785 Link to comment Share on other sites More sharing options...
Simon Waterfall Syman84 Posted March 13, 2017 Share Posted March 13, 2017 This is amazing and such a good price just wish i had the pennies. Would give both nads for it even the Mrs said it's ok Link to comment Share on other sites More sharing options...
