Red Westfield
CedricTheBrave
After a few years of no use what so ever, new business venture awaits so my beloved has to go.
Built in 2007 with 18 swg steel welded in roll bar chassis with additions designed by myself a clad with plenty of carbon fibre apart from the floor which is alloy.
specifications are as follows.
wide track front end with rose jointed top bushes and poly bushed all wishbones (CAT MS)
custom made anti roll bars front and rear (just enough) designed by me
CXR Alloys 7inch front 8 inch rear with R888's
Bremsport calipers with tarox grooved disks
Protect custom valved dampers with two different top hats for road and track heights (85mm track)
Custom CF dash with ETB Digidash 2 starter button etc
Momo suede 265mm steering wheel
Fibreglass Tiled style seats very comfy but fixed passenger side is 25mm lower old red vinyl Westfield seats also available
Sabelt 4 point harness on drivers and Westfield 4 point on Passenger side
Half doors both sides
Fly screen with smoked top section
Red bodywork with removable rear arches
CF rear boot top with top fill fuel filler
rounded style rear lights in CF look housings
CF look front lights with upgraded lamps
Engine is 2.3 non balance shaft Duratec
H beam rods
High comp pocketed pistons
key wayed crank
modified cam chain tensioner
Raceline dry sump system with internal chain driven scavenge and pressure pump
Raceline crinkle finish cam cover and cam chain cover modified for low bonnet
low line bell housing
Alloy radiator and Oil tank with small 9 row oil cooler
Simpson exhaust system custom made to Mountune length primaries
large valve head CNC ground inlet and exhaust ports for maximum flow
AP High power clutch plate with Raceline small and lightened flywheel hydraulic clutch
Adjustable pedalbox
Geared starter
Daihatsu alternator
45mm Jenvy's with custom inlet to reduce intake noise (rr'd with and without made no difference)
SPC Semi helical CR gearbox with rally design shifter
Looped and swirl pot designed fuel system with HP pump and LP pump feeder at rear
Battery in Passenger footwell
GEMS ecu (I know old but good) with various maps and software if required
I am sure there is a few more bits that I have missed but you get the jist
it was rolling roaded by Track n Road a few times and after the new large valve head made just over 250hp and 200ftlb torque I have the graph somewhere I will find it.
The car is pretty ballistic on the road and a handful on track and now I am getting on and have other interests it really doesn't get used as it should.
It is also easy to MOT as the V5 says no emissions required :) so fully road legal and will come with 12 months MOT
will post some pictures up shortly
£POA
Link to comment
Nice car, but really you should include an asking price in the advert IMO
Link to comment
Sold subject to the usual stuff
that was quick I am now going to cry :(
Link to comment
