Newly built 220bhp Zetec 2.0 Silvertop "Dunnel Option 3" Engine
I have a zero miles since build Zetec 2.0 engine with Dunnel Option 3 kit (212-223bhp) as per here http://www.dunnellengines.com/zetec_carb_optionkits_3.php
The block was acid dipped and fully inspected and uprated Dunnel rod bolts installed when the engine was built by local motorsport mechanic. As mentioned, this has not been run since the build so is basically like new. Also comes with Dunnel shallow wet sump, Raceline water rail, lightweight motorsport alternator, 45 DCOE’s, Dunnel ECU and loom, custom exhaust manifold for Westfield, spare standard Zetec 2.0 engine. £3500 o.n.o.
I also have a type 9 rocket box, not sure of ratios.......
Also a Quaife QBM1M Sequential gearbox with drop gear set, position display indicator and geartronics flat up shift unit....
PM me if interested.
  • 2 weeks later...
Engine Sold!
STILL FOR SALE -  Quaife QBM1M Sequential gearbox with drop gear set, position display indicator and geartronics flat up shift unit, hydraulic clutch.
Gearbox now sold, thanks for the inquiries.
