S2T Posted August 31, 2016 Posted August 31, 2016 Just browsing through various regulations. Why does the Westfield Speed Series use a cut off of 1800cc for say roadgoing whereas the various other Speed Championships use 1700cc. Just struck me as being a bit odd but I am sure someone will enlighten me as to the reason Quote
XTR2Turbo Posted August 31, 2016 Posted August 31, 2016 I understand it was requested by the factory as 1800 Zetec Westfield was a popular car. Quote
Terry Everall Posted August 31, 2016 Posted August 31, 2016 originally the 1700cc crossflow was popular but then when the factory started to make and sell kits for the Zetec 1800cc engine it was thought that it probably had the same power as a tuned crossflow and so our limit was raised to 1800cc. I personally think we would be better dropping it to 1700cc like other clubs so our classes are the same in capacity 1 Quote
Arm Posted August 31, 2016 Posted August 31, 2016 It came from competitors rather than the factory. Was a much debated item. Quote
XTR2Turbo Posted August 31, 2016 Posted August 31, 2016 What do caterham do with the 1800 K series class? Quote
John Loudon - Sponsorship Liaison Posted September 1, 2016 Posted September 1, 2016 What do caterham do with the 1800 K series class? Replace head gaskets quite often 2 Quote
Dave Eastwood (Gadgetman) - Club Chairman Posted September 1, 2016 Posted September 1, 2016 Replace head gaskets quite often ouch! Quote
Captain Colonial Posted September 1, 2016 Posted September 1, 2016 Replace head gaskets quite often Quoted for truth Quote
Nick Mace Posted September 1, 2016 Posted September 1, 2016 Replace head gaskets quite often As a former K series owner (Elise), I can vouch for this . Quote
XTR2Turbo Posted September 1, 2016 Posted September 1, 2016 If you were setting it today without any prior constraints I guess it would be 1600 and 2000 Quote
John Loudon - Sponsorship Liaison Posted September 1, 2016 Posted September 1, 2016 If you were setting it today without any prior constraints I guess it would be 1600 and 2000 I doubt it! Look at the engine capacities for classes as events. Nat A is upto 1400 and 1401 - 2000 and nat B is upto 1700 and over 1700 Quote
XTR2Turbo Posted September 1, 2016 Posted September 1, 2016 I said without constraint not based on existing classes Is there a 1.7 litre engine made today? Quote
graham frankland Posted September 1, 2016 Posted September 1, 2016 Lotus Seven Club use 7 engine grade classes 1. K Series 1600 cc, max 125bhp and 1400cc +Supersport Upgrade fitted by Caterham 2. K Series 1800 cc, max 155bhp 1A tyres only 3. K Series 1800 cc, max 155bhp 1A & 1B tyres 4. Any engine not in above up to 210 bhp 1A & 1B tyres 5. Any engine that does not meet above not with sequential gearbox 1A & 1B tyres 6. Any engine and gearbox not in above + driver aids & 1A & 1B tyres 7.Anything else Glutey Quote
Terry Everall Posted September 1, 2016 Posted September 1, 2016 I thought some of the road going Caterhams ran ZZR tyres which were fitted as OE Quote
