chris sideways Posted January 20, 2003 Share Posted January 20, 2003 I will be fitting a 6 point harness in to my car soon I was wondering where the best place is to fix the leg straps,is it coming straight up from under the hole in the seat which will mean welding in some sort of fixing or could I fix it to the beam which takes the seat cradle but this would mean having the straps coming under the seat then up though the hole would that still work or would the angle of the straps be all wrong? Thanks. Chris. Quote Link to comment Share on other sites More sharing options...
Blatman Posted January 20, 2003 Share Posted January 20, 2003 Fit the straps to the lower rear harness mounts (ie where the lap belts are fixed to) and run them up through a hole in the seat. Don't forget to use longer bolts and appropriate spacers....... Quote Link to comment Share on other sites More sharing options...
Fast Westie Posted January 21, 2003 Share Posted January 21, 2003 Chris 6 point harnesses, this sounds serious Still up for the SEMSEC stuff then? Blatman Where does one cut the hole to run the harness through? COuld you just run them back through the side holes? Quote Link to comment Share on other sites More sharing options...
Blatman Posted January 21, 2003 Share Posted January 21, 2003 In the Westfield race seat, I've seen holes *just* cut into the seat in the "right" spot for the driver, and finished off with the same oblong plastic harness hole thingys that the 4 points go through. I haven't done it myself, but it's a mod I'm considering when I have some more time. Perhaps the factory or Plays-Kool could help......... Quote Link to comment Share on other sites More sharing options...
