PINTO AND OTHER ITEMS FOR SALE
I am currently converting my 2.0L Pinto engined Westfield from carburettors to fuel injection and have a number of components surplus to requirements. The car has covered around 2000 miles since built and everything for sale is in good serviceable condition. Everything was working when removed from the car.
Pair of Weber DCOE 45 (152) Carburettors (No manifold) NOW SOLD
Weber DCOE 45 Carburettors
These carbs were purchased new when the car was built and are a matched pair. They were fitted to a 2.0L Pinto engine with a Stage 2 cylinder head and ultimate road cam. They are jetted as follows:- .
Chokes 36, Emulsion Tubes F16, Pump Jets 40, Idle Jets F8/65, Air Correctors 190, Main Jets 150 and Aux Venturi 4.5
Fitted with twin cable throttle linkages
Air Trumpets (26mm)
Includes mounting kit (Misab plates, Thackerey washers etc.)
Also have some literature on set up etc.
£ 450.00 (Includes UK postage)
Collection of Weber DCOE 45 Jets, Tubes etc. (4 of each unless otherwise stated). NOW SOLD
Weber DCOE Jets
Some are new and unused. Others used for tuning.
Air Corrector Jets 155, 170,180 & 200
Idle Jets F8/60, F9/50, F9/55, F9/60 & F9/65
Pump Jets 45
Emulsion Tubes F2
Auxiliary Vent Lock Screw (1 only)
£40.00 (Includes UK postage) NOW SOLD.
Webcon Carburettor Mesh Filters NOW SOLD
Webcon Mesh Filters
Set of 4 low profile filters to fit trumpets of 63mm diameter. Good where engine bay space is restricted.
£ 30.00 (Includes UK postage) NOW SOLD.
AN-6 Weber Carburettor Fittings. NOW SOLD
Weber DCOE 45 Fuel Line
Made in black aluminium alloy and connected with short length of stainless steel braided hose. Swivel seal tee and single end. Sorry only one banjo bolt but obtainable on internet (around £13) or could use standard Weber banjos (M12 x 1.5mm)
£ 35.00 (Including UK postage) NOW SOLD
Aldon (Non vacuum) Distributor (Model 104FPRI) and Luminition Performance Ignition Kit.
Aldon Distributor & Lamination Ignition Kit
The Luminition system comes complete with ignition module, matched coil, connection leads etc and the distributor is fitted with the “windmill” inside the plug cap. Instruction sheet included. The distributor may not have been purchased from new and could be a bit older but was working satisfactorily when removed.
£ 250.00 (Includes UK postage)
Facet Fuel Pump NOW SOLD
Facet Fuel Pump
Complete with filter and short connection hose. (Low pressure type)
£20.00 (Includes UK postage) NOW SOLD.
Filter King Fuel Pressure Regulator (Carburettor Low Pressure) NOW SOLD
Fitted with male AN-6 hose ends but easily changed to BSP barbs if required. Complete with mounting bracket and instructions. Also included is pressure gauge for use during initial set up (gauge adaptor required)
£ 35.00 (Includes UK postage) NOW SOLD
Will do my best to answer any queries.
I'd like the jets and mesh filters please. You have pm
Dibs on the fuel pump please.
PM sent.
Hi,
Weber jets, mesh filters and fuel pump now sold.
Nickietam.
Hi
Filter King regulator and AN-6 Fuel lines now sold.
Nickietam.
