Caterham 13" R400/R500 wheels with Avon ZZR Sprint Tyres
Hi all,
I have a set of Caterham 13" R400/R500 wheels with Avon ZZR super soft sprint tyres which won't fit my new car, so they have to go.
Front: 6x13" wheels, Ford PCD and bore, ET24. Great condition, no kerbing, dings or buckles, but a small amount of bubbling to the inside. 185/55r13 tyres, date stamped 0313 but always been stored in a dry warehouse out of sunlight. Have very few heat cycles and still 4mm of tread remaining.
(Click photos for larger versions)
Rear: 8x13" wheels, Ford PCD and bore, ET24. Great condition, no kerbing, dings or buckles, but a small amount of bubbling to the inside. 215/55r13 tyres, date stamped 0313 but storage / heat cycles as above. 4.5mm of tread remaining on these.
A bit of pickup from the last event but that will come off with a few road miles or half a lap of track use! (Wheels just been washed, hence the odd photo)
Tyres approx £450 new, closest wheels available now are the CSRs (7" front and 9" rear) at just shy of £800 a set new, so I think £550 for these would be a fair price? Can deliver to anywhere in mainland UK for £25 extra, or collection from near Preston (or anywhere else if I'm out and about in your neck of the woods).
Cheers,
Adam
Very very tempted!!!
At Anglesey for a track day on 4th Sept if that helps, so will be passing - ish - and Oulton on 13th September... :)
Hi Adam
Would you sell the rears separately ?
Yes - providing I have someone happy to take for the fronts :t-up: I guess £300 rear and £250 front, ish?
Hi Adam. I'm interested in these, but they are to go on a fury. Why won't they fit on the Phoenix?
They won't fit on my Fury at the rear due to being too wide. Mine's an IRS with drums. I think you could do it with some arch chopping / extending but it's not something I fancy doing.
Edit: Just had a check. The upper wishbone to upright mount fouls the inside edge of the rim. You could make them fit by spacing the wheel away from the hub about 20-25mm, but then the wheel would stick out from the tub by that much. Hope that makes sense!
Thanks Adam. That makes sense. Mine is a live axle with discs. (none of this new fangled IRS stuff) I will have a look tomorrow night to see what room I have and if they have not sold I'll drop you an email.
No probs. Hub face to front of wheel is about 4", to rear is just under 6" - hope that helps.
Caterham wheels sold pending transfer of funds. Thanks.
Caterham wheels being posted today, Minilites also now sold to BudSlater - thanks :t-up:
