Chriscooper1 Posted July 17, 2015 Share Posted July 17, 2015 Hi, I'm looking for a cheap windscreen for my 98 seiw, I've got aero screens on at the moment but was wanting to be able to swap between the 2, does anyone no where I could get what I need? Thanks, Chris. Quote Link to comment Share on other sites More sharing options...
daggartuk Posted July 18, 2015 Share Posted July 18, 2015 You could try putting a wanted ad in the 'parts wanted' section. 1 Quote Link to comment Share on other sites More sharing options...
SootySport Posted July 19, 2015 Share Posted July 19, 2015 The easiest way of changing over between the two, is buy the standard windscreen and pillars with mirrors, then buy AA composites aeroscreen http://forum.wscc.co.uk/forum/index.php/topic/102226-interchangeable-aeroscreens-for-se-sew/. AA aeroscreen use two shorter pillars that fit the same screw holes as the standard pillars, then you can swap between the two screens in about ten minutes. If you want changabiltiy between a normal windscreen and the bubble type aeroscreens then you need two scuttles with each type of screen set up. Quote Link to comment Share on other sites More sharing options...
