scubajess Posted April 17, 2015 Posted April 17, 2015 FOR SALE DUE TO CHANGE IN FAMILY CIRCUMSTANCES. 1991 WESTFIELD SE (Narrow Body) 2L VAUXHALL RED TOP XE ENGINE. Vauxhall 2L Red Top XE fitted with Coscast cylinder head and producing 188.9 BHP (Print out available) The engine has been completely rebuilt using ARP con rod bolts, New cam belt, water pump, QED sump with baffle, carbon fibre cam cover, full set of silicon hoses, QED oil short filter adaptor and filter FUELING AND IGNITION Jenvey throttle bodies and trumpets. ITG air filter. Custom made 37 litre long range alloy fuel tank with built in swirl pot. DTA ECU with DTA wiring loom. Coil pack (Distributer removed) EXHAUST Westfield 4 branch manifold connected to a Wunoff repackable 6" diameter stainless steel silencer. TRANSMISSION Gearbox is a Quaife 5 speed semi-helical close ratio Ford Type 9. Ratios are 1st - 2.39. 2nd - 1.54. 3rd - 1.21. 4th - 1. 5th - 0.87 REAR AXLE It is a Ford RS2000 3.9 ratio 'live axle' fitted with a tran-x plate type LSD set at the correct ramp angle for a light weight kit car. SUSPENSION Protech adjustable alloy bodied shocks all round. All front wishbone and rear axle tie bar metalastic bushes were recently replaced. New tie bar to chassis mounting brackets fitted and strengthened with extra bracing plates. WHEELS/TYRES 15" OZ Ultraleggera lightweight alloy wheels fitted with 195/50x15 Toyo tyres. STEERING. 2.4 lock to lock quick rack BRAKES Front - Ford M16 calipers fitted with EBC 'Green Stuff' pads. Vented discs. Rear - RS2000 9" Inch drum brakes. INTERIOR Genuine carbon fibre dash fitted with rev counter, oil pressure gauge, water temperature gauge, amp meter and SPA programmable digital speedometer. The dash also has all the usual switches and warning lights fitted in addition to a fuel cut off switch and a shift light. The seats are MK fibreglass high backed seats. Recently fitted Luke 4 point harnesses. 11" Mountney steering wheel BODY Narrow Body in very good condition. Fitted with carbon effect front cycle wings and carbon effect rear arch protectors. RAC roll bar fitted with high level LED brake light. 5 1/4" carbon effect headlights. There are a number of vinyl graphics on the bodywork. These can be removed very easily but I do not want to remove them as if it doesn't sell I will obviously be keeping it and I personally like them. ADDITIONAL INFORMATION PowerVamp gel battery fitted. Custom made radiator – no cooling issues whatsoever. The car has been completely rewired using a professionally made custom wiring loom. Also included in the sale is an unmarked tonneau cover and a boot box cover made from the same material. The car is correctly registered as a 2 litre Westfield SE and the correct engine number is shown on the V5. 12 months MOT. £6,500 OVNO I am in Rotherham, South Yorkshire 5 minutes from J.33 M1 or 15 minutes from J.1 M18. I think I’ve covered everything but if anyone requires any further information please PM me or ring me on 07522 125339. 1
AdamR Posted April 17, 2015 Posted April 17, 2015 Looks lovely! How much are you after for it? Edit: You beat me to it I don't think it'll hang around long at that price...!
scubajess Posted April 17, 2015 Author Posted April 17, 2015 it's at the end of the listing just before my location. Now in bold figures.
Tricky Posted April 18, 2015 Posted April 18, 2015 This is a pretty little red rocket, sure you'll sell easy at that price, good luck with the sale................ I think
Mike Rowland - Essex AO Posted April 18, 2015 Posted April 18, 2015 Looks a bargain for someone! Good luck with the sale, but I don't think you'll need it...
scubajess Posted April 22, 2015 Author Posted April 22, 2015 Thanks to the people who phoned regarding my car but it is provisionally sold, deposit taken. not sure whether to be happy or sad!
scubajess Posted April 23, 2015 Author Posted April 23, 2015 Going to Nottinghamshire, somewhere around M1 J.27 I believe.
