How about this engine for a wild project somewhere? Bargain!
msisleman
I bet theres a story behind that...
Link to comment
There has to be!
Link to comment
I assume direct injection and so with 12 cylinders will be a non trivial ecu programming exercise.
Link to comment
I still want it.. :o
And I don't care what you say after seeing a lambo v12 in a fiat 500 then this will fit in a Wessie.
Might not be any bodywork at the front but you can't have everthing.
  • Like 3
Link to comment
It is DI yes, and electronic throttles, and variable intake and exhaust cams, and god knows what else.
But it's still so awesome! Might be best to get hold of the original ECU to be honest. And then what gearbox would you use?! One can dream.... Still seems priced keenly though for a £50k crate engine.
Link to comment
I've got an F12 to type 9 bellhousng kicking around somewhere.
Link to comment
Trouble is these days, the engine ECU wants to see the transmission ECU, both want to see the body control ECU...
This engine keeps coming round again, (either that or there are a lot of similar historied FF engines out there!) each time, I seem to recall the story from those that know modern Ferraris, is that while it's a thing of beauty to behold, it's remarkably tricky/expensive to actually do anything practical with it.
Link to comment
Yep. I'm sure it will simply end up back in an FF that has engine issues outside of its 3 year warranty period.
Link to comment
How many /Dellorto/Webers would you need to bolt on that then?
Link to comment
  • 2 weeks later...
How about this instead?
271540018048
This Will fit!!!
Link to comment
I've seen that ad a few times over the years. Just shows how ludicrous the cost of top rallycross is. I cannot even begin to imagine spending £61k on an engine, never mind an "old" YB!
Must be a market for them...
Link to comment
