Steve M Posted March 14, 2015 Posted March 14, 2015 Hello all, I've noticed that my right front cycle wing is hitting my bodywork on full right hand lock, is there a way I can stop this by adjusting something? I've not long had the Geo set up, so wouldn't want to mess that up Also, is there any point mentioning if there is some sort of touch up stick available, Im guessing not, as there are so many variants Quote
Dave Eastwood (Gadgetman) Posted March 14, 2015 Posted March 14, 2015 Westfield use "lock-stops" within the bellows of the steering rack normally to prevent this. They're just collars either bolted on or sometimes permanently built in, that limit the travel of the steering rack's innards. If you don't have them, it's possible to retrofit by sliding the rubber bellows back and bolting them in. It's not something as far as I know that Westfield can supply, but places like RS Components do bolt on collars that people have used in the past. Quote
Dave Eastwood (Gadgetman) Posted March 14, 2015 Posted March 14, 2015 As for touching up, it's a tricky one. You can buy pots of gel coat to fill deep gouges, but as gel coat fades with time and can vary ever so slightly batch to batch, it's probably not going to be perfect. Your best bet is to go to your local trade paint supplier and get them to colour match the bodywork and make a small pot of paint up for you. (Or fill an aerosol if you prefer). Quote
Stu Faulkner Posted March 14, 2015 Posted March 14, 2015 I have used T-cut in the past to clean of marks and light scuffs and then polish afterwards. Heavier scuffs can be worked on with 1500 wet and dry. Quote
Aerodynamix Ltd Posted March 14, 2015 Posted March 14, 2015 I've seen jubilee clips used before Steve , you would only need to slip the rack boot off and if you undid the jubilee and did it back up after you has slipped it over you would not disturb the track rod end then and your new set up , as Stu said you could try flatting it off and then perhaps some g3 after flatting it . 1 Quote
pete g Posted March 14, 2015 Posted March 14, 2015 you can fit steering lock stops or fit wide track body work is easy just get some g3 rubbing compound and polish it out Quote
Rab (bombero) Reid Posted March 15, 2015 Posted March 15, 2015 What Julian (Aerodynamix) said. Gelcoat is more robust than standard paint so the light scuffing that you've got should easily come out. Still be patient however when doing it. Quote
lloydox Posted March 15, 2015 Posted March 15, 2015 Just wondering was it hitting the bodywork before you had the geo done ? Quote
Steve M Posted March 17, 2015 Author Posted March 17, 2015 @lloydox..I don't think it was I've taken the boot clip off & pulled it back, there is a threaded part on the rack, I would have thought I could adjust the lock by turning the knuckle along the thread, but it won't budge Quote
Kingster Posted March 17, 2015 Posted March 17, 2015 I'm not sure - but I wouldn't be touching that (until someone more knowledgable comes along). Any 'lock stop' will be a collar style addition AFAIK. Quote
Terry Everall Posted March 17, 2015 Posted March 17, 2015 Unless you drill out the locking "pin" between the main body and the outer locking ring it not move!! BUT it is only removed to install longer or short arms and does not have a thread that alter the steering arm length. You can only alter the toe in at the outer ends If you ever do drill the pin out it needs a metal filler to reinstate it. Quote
Westford Posted March 17, 2015 Posted March 17, 2015 You don't want to be adjusting that, it is for adjusting the end float in the ball joint on the steering arms. Quote
pete g Posted March 17, 2015 Posted March 17, 2015 that is for adjusting the knuckle joint don't undo that .and you cant till you drill out the pin. the shaft between the joint and rack you can I believe you can fit a jubilee clip and it will stop the travel of the rack. I have never done it but people say its possible . I think that's where the westfield lock stop goes. Quote
Lyonspride Posted March 17, 2015 Posted March 17, 2015 @lloydox..I don't think it was I've taken the boot clip off & pulled it back, there is a threaded part on the rack, I would have thought I could adjust the lock by turning the knuckle along the thread, but it won't budge How about something like this http://uk.rs-online.com/web/c/pneumatics-hydraulics-power-transmission/power-transmission-bushes-collars/collars/?redirect-relevancy-data=636F3D3126696E3D4931384E44656661756C74266C753D656E266D6D3D6D61746368616C6C7061727469616C26706D3D5E5B5C707B4C7D2D5C707B5A737D5D2B2426706F3D3926736E3D592673723D52656469726563742673743D4B4559574F52445F4D554C54495F414C5048412673633D592677633D4E4F4E45267573743D636F6C617220636C616D7026&r=f&sra=oss Quote
Dave Eastwood (Gadgetman) Posted March 17, 2015 Posted March 17, 2015 Yes, those what I've seen quite a few people use. Quote
