marka Posted July 25, 2023 Share Posted July 25, 2023 Thanks for that...think mine is a "kit". However when buying bodywork etc say from Westfield Chesil, they only seem to stock either ZK or FW items. Would ZK bodywork items like nose cones, front grilles etc fit a "kit" wide body do you know? Many thanks.👍 Quote Link to comment Share on other sites More sharing options...
Mark (smokey mow) Posted July 26, 2023 Share Posted July 26, 2023 8 hours ago, marka said: Thanks for that...think mine is a "kit". However when buying bodywork etc say from Westfield Chesil, they only seem to stock either ZK or FW items. Would ZK bodywork items like nose cones, front grilles etc fit a "kit" wide body do you know? Many thanks.👍 The previous owners of Westfield discontinued the kit bodywork long ago when they released the ZK. they’re similar but not entirely interchangeable and fettling will be required to make them fit. if changing a nose then you’ll also need a bonnet and scuttle at the same time as the shape and profile is different. Quote Link to comment Share on other sites More sharing options...
marka Posted July 26, 2023 Share Posted July 26, 2023 Many thanks, I get it now. Much appreciated. Quote Link to comment Share on other sites More sharing options...
Andy - a15cro Posted July 26, 2023 Share Posted July 26, 2023 I have a set of extra wide available I’m going to sell, never fitted. I also have led rear lights and reverse leds. Quote Link to comment Share on other sites More sharing options...
corsechris Posted July 26, 2023 Share Posted July 26, 2023 21 hours ago, marka said: Thanks for that...think mine is a "kit". However when buying bodywork etc say from Westfield Chesil, they only seem to stock either ZK or FW items. Would ZK bodywork items like nose cones, front grilles etc fit a "kit" wide body do you know? Many thanks.👍 Going back a bit now, but I fitted a ZK V8 bonnet to a ‘kit’ body of ‘91. vintage… but I had to do some surgery on the nose to make it match up. It did line up nicely with the original scuttle though. Given how things have changed over the years, it’s entirely possible that the bonnet was different to what they produce now. For example, it didn’t have any alignment dimples in it. Quote Link to comment Share on other sites More sharing options...
marka Posted July 26, 2023 Share Posted July 26, 2023 2 hours ago, corsechris said: Going back a bit now, but I fitted a ZK V8 bonnet to a ‘kit’ body of ‘91. vintage… but I had to do some surgery on the nose to make it match up. It did line up nicely with the original scuttle though. Given how things have changed over the years, it’s entirely possible that the bonnet was different to what they produce now. For example, it didn’t have any alignment dimples in it. Thanks thats interesting...still trying to educate myself on the finer nuances of the bodywork! , my bonnet has no lugs and has four securing clips, so mine is deffo a "kit"...I think! 🤣 Quote Link to comment Share on other sites More sharing options...
Mark Brown 1 Posted August 27 Share Posted August 27 Hi all, Does anyone know the width of the Standard FW arches vs extra wide? I have tried searching but to no avail! Thanks, Mark Quote Link to comment Share on other sites More sharing options...
Smudge62 Posted August 27 Share Posted August 27 The extra wide one is 40mm wider than the standard one 1 Quote Link to comment Share on other sites More sharing options...
Mark Brown 1 Posted August 28 Share Posted August 28 Thanks Smudge, do you know the actual width of either? I'm trying to identify what is fitted on a car I have just purchased, prior to ordering some arch protectors Quote Link to comment Share on other sites More sharing options...
Smudge62 Posted August 29 Share Posted August 29 From the rear tum to side panel joint it is exactly 260mm on the plus 40mm extra wide arches Quote Link to comment Share on other sites More sharing options...
Alan Cutler (Adge) - Dorset AO Posted August 30 Share Posted August 30 ties up with my standard width arches, 220mm wide at same position. Quote Link to comment Share on other sites More sharing options...
Mark Brown 1 Posted August 31 Share Posted August 31 Perfect, thanks a lot for getting that measurement! Quote Link to comment Share on other sites More sharing options...
