Mightyness is also measured in soul Reverend Terry...
Ok, missus give the go ahead now, so this is my car spec,
Rollbar standard,
Oil catch tank 1 litre,
Battery cut off on exterior of car, need sticker for on/off.
3 pt will ans harnesses,
1700 x flow mighty I hope, road registered.
What more will I need to sort?
Also need some gear to where?, where is the best to source this, as on a budget...
You need an MSA licence, helmet, gloves and overalls to MSA requirements. Most use race boots.
I think you now need 4 point harnesses and you would need someone to look at your roll over bar and advise if its ok. Can you post a picture on here.Most of us have the battery cut off switch on the dash or tunnel so we can reach it. Any ignition switch must have an on/off sticker. You will also need to fabricate and attach a timing strut to the front of the car.
You don't need a battery cut off , you only need sticker for ignition switch
But if you have a cut off switch fitted it must work and have a sticker
It's in the members gallery think turbos sei
Does anyone sell a timing strut?, I have ignition key to make live, then a push button start, as well as bat cut off
Only have 3 points on the chassis for my harnesses
You really need a proper MSA/RAC roll over bar for safety
As Terry says RAC roll bar as a minimum & 4 point harnesses  "thinksafety"    ;) It doesn't happen often, but a few of us have rolled Westfields :blush: :blush: :blush:
Speak to Luke at Plays-kool er www.plays-kool.co.uk  he'll supply all your safety equipment at cracking prices :t-up:
How do I fit 4 point harness when I only have 3 point fixings?, as there a special thread?.
Also is it a SPEED category Non-race national B (not EU) license for £43????
You can get weld on bushes with the correct thread. I got mine for £8 off eBay
Yeah that's the correct licence. Make sure you get one for 2015 :yes:
Glad you said that, I was half way through completing the 2014 one!!!
