maskiemilner66 Posted October 6, 2014 Share Posted October 6, 2014 regretably for sale:siew chassis mt75 tunnel, pro comp floor mounted pedal set, biased brake.unusedfront upper/lower wishbones ..unusedwestfield fabricated uprights ..unusedalloy hubs n discs ..unusedcalipers ..unusedmudguard brackets ..unusedbraided hosessteering rack ..newupper n lower steering column ..newx2 master cylinders 0.75 ..newx2 light brackets .. re powdercoatedx2 headlight units ..usedzetec loom and fixings ..unused2.0 16v blacktop zetec 80k removed from mondeo estate by me. so i know its a good one. ..used7" lsd ..used4x4 drive shafts ..usedalloy rear uprights ..usedupper n lower rear wishbones ..usedrear hubs n discs ..newrear calipers ..newrac welded rollbar re powdercoatedquick shift type 9 extension ..usedhandbrake lever ..usedsingle grp seat .. needs workbuild standsall of this needs building from bare chassis.there is prob stuff i have forgotten but mostly there.70% to 80% of stuff new.best bit is i have v5 in my name so no iva required once finished!! just build ad you want to and mot!! not going to brake want gone in one lot....located in cheltenham.£3800.00 ovno Link to comment Share on other sites More sharing options...
Wesley Posted October 28, 2014 Share Posted October 28, 2014 Is this still available? 07515 934136 Link to comment Share on other sites More sharing options...
