Mark Williams Posted March 14, 2014 Share Posted March 14, 2014 Geartronics GCU + Gear Position IndicatorRare opportunity to buy a Geartronics GCU (+ gear position indicator) separately, around which you could build a very cost-effective closed-loop gearshift system (only suitable for sequential gearboxes) - not to be confused with the "Easyshift" ECU that Neil also offersCurrently holds the config for a Busa (set-up by Neil)Supplied with female AMP plug but requires a set of pins to wire-inSoftware CD also included (Geartronics calibration software, USB driver, installation manuals and schematics, technical drawings etc) £750 Link to comment Share on other sites More sharing options...
Mark Williams Posted April 14, 2014 Author Share Posted April 14, 2014 bttt Link to comment Share on other sites More sharing options...
Deanspoors Posted April 17, 2014 Share Posted April 17, 2014 Hi Mark, what modifications are required to fit this to my megabusa? e.g. How is the gear position detected? And do you supply and wheel mounted paddles with the kit? Also, are you using any type of flat shifter with this kit? I currently have a flat shifter pro I would like to use. Thanks, Dean Link to comment Share on other sites More sharing options...
Deanspoors Posted April 22, 2014 Share Posted April 22, 2014 Is this now sold? Link to comment Share on other sites More sharing options...
Mark Williams Posted April 22, 2014 Author Share Posted April 22, 2014 Sorry Dean, I've sent you a PM Cheers, Mark Link to comment Share on other sites More sharing options...
