Yontoo Virus removal help
I seem to have the Yontoo virus playing havoc with my laptop.
Google searches have turned up a few leads to remove it, but all the software ive downloaded scan the PC, find the virus and then require payment remove it..
Any of you PC guru's have any tips...
Andy, that's my problem, it wont let me do that ..
when I click on "uninstall" it just says "setup initialization error" and kicks me back out again..
Do you have CCleaner installed? if so, use it to clear out all the browsing history etc, then use the Registry fixer to sort that out and finally use the Tools section to uninstall any and all unwanted applications listed.
If you don't have it, get it, as it's probably the best (free) utility out there :yes:
Thanks peter, installing now...
First tip - don't install stuff that you're not 100% sure of its source and integrity - that'll stop it hapening again. But as the stable door is open :-), you'll need to remove it manually (and any other assocoated programs which will just reinstall it when you reboot.)
Try this
http://fixingcomputervirus.blogspot.co.uk/2013/04/simply-remove-yontoopagerage-uninstall.html
You'll be editing the windows registry so if you're not completely comfortable with that - get someone to do it for you. I'd offer but you're too far away, sorry.
Once you've done all that - run ccleaner, buy and install Kaspersky Internet Suite (best protection around - you'll get it on Ebay and upgrade online to the latest version) and don't install stuff!!
Ah, OK. Can you start in safe mode (F8 on PC startup to selct this option). What OS are you running?
