SEiGHT Posted January 10, 2003 Share Posted January 10, 2003 At the top of page 5 on the SS2003 rules PDF Steve sent out it says... "In all classes roll-cages must be fitted..." Now while I'm assuming that a roll-bar is sufficient based on past conversations, I wouldn't class a roll-bar as a roll-cage myself so am a little concerned. Does the MSA blue-book define a roll-cage as including roll-bars ? Quote Link to comment Share on other sites More sharing options...
Graham.J Posted January 10, 2003 Share Posted January 10, 2003 It's a typo, as far as I know you can still use the original bar westfield supply for the speed series so no a full cage is not mandatory, just something to protect yer bonce if you do go t*ts up Regards Quote Link to comment Share on other sites More sharing options...
Mark Stanton Posted January 11, 2003 Share Posted January 11, 2003 Yep a roll bar is fine - used the term roll cage as opposed to roll bar so as not to get confused with anti-roll bar which is something completely different and also not mandatory Quote Link to comment Share on other sites More sharing options...
SteveD Posted January 11, 2003 Share Posted January 11, 2003 just be carefull with the standard westfield roll hoop ( without diagonal or rear braces ) some scroutineers won't allow you to run with standard roll hoop ,and for your own safety you should fit a braced cage ( with diagonal and rear braces ) if you should topple over the hoop as a tendancie to fold flat Quote Link to comment Share on other sites More sharing options...
