Neil H Posted April 27, 2013 Share Posted April 27, 2013 Black vinyl, with detachable black crash pad. Boss cover included.300mm. Complete with boss for fixing straight to Austin Rover\Allegro column - just removed from '95 SeiWideBeen on car since passing SVA many years ago - assume IVA compliant? Extremely good condition - as new.£30P&P not included. Located in Reading, RG4. Will also be at Stoneleigh Sunday 5th May. Thanks for viewing. Neil Link to comment Share on other sites More sharing options...
darve Posted April 27, 2013 Share Posted April 27, 2013 1st dibs....... just need to check if I can fit to my mazda column Link to comment Share on other sites More sharing options...
Mark (smokey mow) Posted April 27, 2013 Share Posted April 27, 2013 1st dibs....... just need to check if I can fit to my mazda columnYou'll need to make an adaptor Dave, but I have the same wheel fitted to mine Link to comment Share on other sites More sharing options...
Neil H Posted April 27, 2013 Author Share Posted April 27, 2013 Yours if it fits, Dave. Cheers, Neil Link to comment Share on other sites More sharing options...
Neil H Posted April 27, 2013 Author Share Posted April 27, 2013 Note, the wheel will come with the original bolt on boss\adapter = from Austin Rover spline to 100mm PCD of the wheel itself. Link to comment Share on other sites More sharing options...
darve Posted April 27, 2013 Share Posted April 27, 2013 I'll take it pm me payment details, need posting to cm11ln will reply with full address thanks Link to comment Share on other sites More sharing options...
djm Posted April 28, 2013 Share Posted April 28, 2013 You'll need to make an adaptor Dave, but I have the same wheel fitted to mine Hi Mark, I already have one the same for my car and I was wondering what boss I would need, if it was IVA compatible and how the horn will work with it? Does it have to be a collapsible boss for IVA? Link to comment Share on other sites More sharing options...
Mark (smokey mow) Posted April 28, 2013 Share Posted April 28, 2013 Hi Mark, I already have one the same for my car and I was wondering what boss I would need, if it was IVA compatible and how the horn will work with it? Does it have to be a collapsible boss for IVA?I got my collapsable boss from mx5 parts but others should work just as well.There's no boss that I found which works directly with both the mazda column and the mountney wheel so you'll then need to make an adaptor plate, this is mine which adapts the sparco/omp bolt patten to the Westfield/mountney wheel. The horn is wired to a button on the dashboard Neil, sorry for the thread hyjack but I hope this will also be relevant to Darve Link to comment Share on other sites More sharing options...
djm Posted April 29, 2013 Share Posted April 29, 2013 Sorry Neil from me its probably my fault, I'm not up with all the forum procedures! Link to comment Share on other sites More sharing options...
djm Posted April 29, 2013 Share Posted April 29, 2013 I got my collapsable boss from mx5 parts but others should work just as well. There's no boss that I found which works directly with both the mazda column and the mountney wheel so you'll then need to make an adaptor plate, this is mine which adapts the sparco/omp bolt patten to the Westfield/mountney wheel. The horn is wired to a button on the dashboard Neil, sorry for the thread hyjack but I hope this will also be relevant to Darve Thanks for that Mark its great, I'll have to find someone to knock one up for me. One final question on this subject, the horn button on the dash, is that OK for IVA? Link to comment Share on other sites More sharing options...
Neil H Posted May 1, 2013 Author Share Posted May 1, 2013 PM sent to darve. Sorry for delay. Neil Link to comment Share on other sites More sharing options...
