After a fuel tank suitable for Narrow chassis. Not sure if they vary from the wide ones anyway. I need something 700mm wide or less.
Please PM if you have something.
Atlas
I may have one but will need to check dims tomorrow
Is it for injection or carbs?
Running Webbers and pump on a Red Top.
May be OK then but out of my wide so best I pit a tape over it and send you the sizes.
Ken
Thanks Ken
Are you sure about the dimension? The one in my narrow (independant) is 812mm
Will check again but my current one fits between the rollbar stays which as 740mm apart apporx.
So I think Ken yours will sadly be far too wide thanks for the specs though.
Will confirm.
No problem, just let me know. It's there if you want it.
Ken
Hi Ken,
Thanks for the measurements. I've checked mine and the gap between the diagonal bars is 720mm so max tank width can only be
690/700mm.
No problem at all. Good luck finding tank.
