March 2018
Quinten
March 16th, 2018
Spend: £997.40
I picked up my engine from Jody (JA Kit and Customs) today!  Complete checked over, and with most parts replaced she almost looks like she just rolled off the factory floor.
54273360384__C9BFA1B5-0A98-4324-8C8A-D7F928CF8888.thumb.jpg.6b865a5f8ad2e7948fbb6fec818acd69.jpg
March 17th, 2018
Spend: £0.00
With the Beast from the East making a return the conditions outside and in the garage are awful.  But I'm determined to not let it spoil my rekindling with the Westfield!  Ensured the gearbox input shaft and spigot bearing were not interfering and then put the gearbox back into the car with the help of my son.
March 18th, 2018
Spend: £28.80
Putting an engine back can take 5 minutes, or 5 hours.  I ended up somewhere in the middle when after yet another minute change in position the engine finally mated with the gearbox and bellhousing.
March 24th, 2018
Spend: £32.59
Miserable weather outside so had to do all the work inside the garage.  Not ideal.  Connected everything up and then discovered that I should have bolted the PCV breather pipe that goes just above the bellhousing from one side of the engine to the other should have been one of the 1st things to go back, not the last.  Oh well, I'm not taking it apart again, so managed to lock it in place as well as I could.  Another thing I now discovered is that my water temp gauge sensor wire seems a bit short.  Weird as nothing changed in the location, so I need to fix that as it looks a bit strained at the moment.
Could not start the engine due to the weather, but forecast is really good for tomorrow
March 25th, 2018
Spend: £0.00
Up early (not helped by the bl**** clocks going forward and a AUS F1 race early in the morning) and got the car out of the garage.  Fluids checked and topped up, plugs removed and hit the starter button so it would start to build up oil pressure.  With the gauge now part of my system the needle rose nicely and after doing this a couple of times decided to fit new plugs and go for it!
Asked Mrs Q to film the start, but to my surprise nothing happened.  The engine would just turn over and over and over, but not fire into life.  b*****ks.  Mrs Q asked if the battery was charged, and like last year I'd fallen into the trap of trying to start the engine with a low battery.  Doh!  Half an hour on the charger and then...
Had to change the accelerator cable tension slightly to set the RPM to a steady 1000RPM, and still have to adjust the clutch cable.
March 30th, 2018
Spend: £0.00
With the threat of p*** poor weather, I sneaked out early and rolled the car out of the garage.  Adjusted the clutch cable so it now seems to work ok for 1st, 2nd and reverse.  Can't test it any further as I'm still on SORN.  Put the nose cone and air filter back on and replaced the batteries in the security gate opener.  Am leaving the bonnet off for now, until I've triple checked everything.  Also taxed the car online starting from the 1st of April...  no joke!
Last month: £  6379.80
This month: £  1058.79
Total:      £  7438.59
  • Like 4
0 Comments
Recommended Comments
There are no comments to display.
