Store Testing In Progress ×
  • entries
    10
  • comments
    35
  • views
    65,894
Part 3 - Brass Monkeys!
JPLS
blog-0929022001359737108.jpgBeen a little while since my last update - some progress made, slightly beaten by the cold weather, but persevered :)
All brake and fuel pipes now installed - routed the two fuel pipes either side of the Clutch master cylinder to give me plenty of clearance for the gearbox/clutch slave cylinder.
http://s1358.beta.photobucket.com/user/scraggj/media/IMG_0144_zps73afa94e.jpg.html?sort=3&o=3
Getting heavy to turn the chassis - the wife is starting to complain. Perhaps I should offer some help!
Sick of riveting and pipe bending so I moved on to some spannering - trial fitting the front and rear suspension. The 4" bolt supplied for the top rear suspension mount is too short - will refit with a 4.5" when I reassemble - the shocks and diff bracket will have to come off before I install the diff anyway.
http://s1358.beta.photobucket.com/user/scraggj/media/IMG_0146_zps80811c58.jpg.html?sort=3&o=2
http://s1358.beta.photobucket.com/user/scraggj/media/IMG_0147_zps633270e4.jpg.html?sort=3&o=2
Done some painting - front uprights.
http://s1358.beta.photobucket.com/user/scraggj/media/IMG_0148_zps014b0f5f.jpg.html?sort=3&o=1
and Diff housing
http://s1358.beta.photobucket.com/user/scraggj/media/IMG_0149_zpsa4986fad.jpg.html?sort=3&o=0
Can you guess the body colour I have opted for then?
I have chosen to replace bearings at all 4 corners - so rear uprights will need some professional help or a BFH to releave them of their old bearing shells. Any hints?
Completion kit due in March, so plenty of time to get the uprights fettled and then I can turn to look at what the engine and gearbox need........
CYA next time. :t-up:
PS - How do I add photos to this blog without using photobucket?
4 Comments
Recommended Comments
Mark (smokey mow)
The hub nuts on the rear uprights are torqued to 236-318Nm (174-235 ft-lbs) :oops: you'll need a minimum of a 3/4" drive breaker bar and a lot of wheatabix for breakfast to budge them.
Link to comment
Hub nuts were slackened easily enough (!!) whilst the original MX5 was still on its wheels, so  were not really a problem once on the bench. Rear bearing shells, now thats a diferent matter - will give it some thought over this weekend.
Link to comment
