Quinten's Mighty Blog
  • entries
    64
  • comments
    22
  • views
    85,165
February 2016
Quinten
February 7th, 2016
Spend: £0.00
Armed with white spirit, brake cleaner, cloths and wire brushes attacked all the nooks and crannies to make it as clean as possible. I'm changing plans slightly; originally I was going to use carpet glue to stick the carpets down, which requires a very clean surface, but now I think I will be using Sikaflex instead as it would provide the same bond, but is a lot more forgiving on the surface prep.
Next step, making carpet templates...
February 12th, 2016
Spend: £5.00
I bought the carpet nearly a year ago, but it's taken up until today to do something with it. Quite difficult to get the dimensions right, but my first panel is done :yes:
February 14th, 2016
Spend: £0.00
Could not continue yesterday as it was raining, so after a nice Valentine's breakfast I spend more time with the carpet. Almost done :yes:
February 20th, 2016
Spend: £0.00
Final bits of carpet cut.
February 21st, 2016
Spend: £10.09
Have not appreciated how much Sikaflex EBT+ is required to fix one panel of carpet, so I ran out! Ordered 3 tubes from CPC which should be ample.
Fortunately I still had a small job to do: fit my CTEK dash panel
February 26th, 2016
Spend: £8.99
Nearly done now. Just the back panel and tunnel top to complete.
February 27th, 2016
Spend: £0.00
Luxury plush carpets!
February 28th, 2016
Spend: £39.00
Another small job I'd postponed until today is fitting the Firmtec Sequential Shift Light which Santa kindly brought me. Unfortunately it doesn't seem to do anything so I will have to remove scuttle/dash again and see what my wiring is like.
Seats back in, carpets done, tax paid for... bring on Spring!
Last month: £  2122.67
This month: £    63.08
Total:      £  2185.75
1 Comment
Recommended Comments
carbon-nv
Looking good Quinten. Hope to catch up with you this Monday.
