Quinten's Mighty Blog
  • entries
    64
  • comments
    22
  • views
    85,415
September 2015
Quinten
September 6th, 2015
Spend: £25.00
Julie kindly organised a (very) small group buy on a stainless steel laser cut Westfield badge and today I fitted mine.
September 13th, 2015
Spend: £0.00
Another weekend spend to investigate why the DRLs switch off with the engine running. Have taken the brave pill and partly rewired everything so that I can access the fuses easier when the scuttle is on. Also rewired the indicator/hazard circuit, but this made no difference whatsoever. Somehow there is a current on the indicator circuit both when the engine is off and running. Even when I had disconnected all indicator end points it would not go down to 0V. As a last resort I put another relay on the indicator circuit (to only switch current to the indicator on the DRL when the indicators are being used) and this did the trick. It adds another failure point into the wiring, but I'm past the point of caring :(
September 20th, 2015
Spend: £1.95
Deja vu! Yet another weekend spend to investigate the DRLs. Whatever the cause, I don't know, but I finally managed to get it working, in a completely different way that I would never have thought to be the solution. As per last weekend, I don't really care anymore so just enjoy the photo ;)
Last month: £  2095.72
This month: £    26.95
Total:      £  2122.67
1 Comment
Recommended Comments
Kevin (Mr T)
Great Blog.
Your DRLs look the absolute dogs.
Even Mrs T has enjoyed reading through your entries and won't look at mine!
