Quinten's Mighty Blog
  • entries
    64
  • comments
    22
  • views
    85,225
August 2015
Quinten
August 1st, 2015
Spend: £9.03
Fabricated a muselet which should hopefully prevent the filler cap from popping off again.
August 2nd, 2015
Spend: £1.99
Continued with fitting the DRLs and after testing it over and over again put the dash back in (had it off as much as I could without removing steering wheel) and tightened the scuttle back discovered that the DRLs would go off as soon as I started the engine... Grrr! Too late in the day to do something about it as I want to drive it to work tomorrow. Should be easy fix though, so maybe I can try at lunch time.
August 9th, 2015
Spend: £18.14
After asking for help on the forums, we concluded that a small load resistor was required to stop the DRL units thinking that the indicators were on, and hence switching off. Tried a few resistor values I had at home, but in the end it would only reliable work if I hooked up a 'ballast' indicator bulb. So it seems I just need a 6 Ohm, 50 Watt resistor as used in many LED conversion application. Nothing I can get today though.
After washing the car, I installed some 4mm thick rubber mudflaps which should hopefully cut down on the amount of road crud being stuck to the rear arches.
Last month: £  2066.56
This month: £    29.16
Total:      £  2095.72
0 Comments
Recommended Comments
There are no comments to display.
