Doug Dastardly Posted February 23, 2013 Posted February 23, 2013 Evening all. I need to take my top wishbone off the upright to remove my cycle wing. If you're interested it's to add a third stay to stop them banging about. Can anyone reccommend a splitting tool? I prefer the look of the screw types to the hammer types, but I've never used one. The last thing I want to do is buy one that doesn't fit or isn't suitable. I presume a ball joint can be taken apart and reused? If there's any other advice about the job or tool use please fire away Thanks very much. Doug Quote
Norman Verona Posted February 23, 2013 Posted February 23, 2013 before spending money try this. Undo the nut so the top off the nut is still covering the thread. Then hit the side of wishbone hard with a heavy hammer. They usually come apart. Quote
Doug Dastardly Posted February 23, 2013 Author Posted February 23, 2013 Thanks Norman, I did try hitting the nut upwards, but not hard as I didn't like it. Just to make sure....hit the wishbone, not the upright? Can you do it without damaging the powder coat? Quote
Andy Rob Posted February 23, 2013 Posted February 23, 2013 Hi Doug I bought a screw type one from Halfords as I wanted to split the ball joint to adjust the set up. It worked well, but I noticed when I was putting it back on that I had caused a small tear in the rubber boot on the ball joint. Could have been down to me rather than the tool, but just something to be mindful off, as I ended up replacing it :-( Andy Quote
FILFAN Posted February 23, 2013 Posted February 23, 2013 Yup the hammer always works for me. If it still won't budge hit with 2 hammers at either side Quote
Norman Verona Posted February 23, 2013 Posted February 23, 2013 If you're concerned about the powder coating use a copper hammer or put a piece of copper over the wishbone. Quote
DerekJ Posted February 23, 2013 Posted February 23, 2013 If you go for the screw type make sure it's the "heavy duty" type. like this one... Clicky You can get it in B&Q Halfords etc... Quote
Ian Podmore Posted February 23, 2013 Posted February 23, 2013 Avoid simple hammer in type, been there, had to replace split boot afterwards. I use a screw type one, you know it's always going to work without damaging anything. Quote
Hammy Posted February 24, 2013 Posted February 24, 2013 If using a puller or splitter doing it up tight then a tap with a hammer is a good method. I've seen pullers have threads stripped by over tightening to try and break a joint . Quote
KenP Posted February 24, 2013 Posted February 24, 2013 If you go for the screw type make sure it's the "heavy duty" type. like this one... Clicky You can get it in B&Q Halfords etc... That's the one I use. Works well for me but will not open wide enough for the bottom ball joint on mine. - similar story here, but ten minutes careful work with an angry grinder and a file soon solved that one! Quote
