What Size Spanner Range
Hi All
    As I now need to buy some new AF spanners to work on my Westie What size range do I need I do not want to buy 15/16" , 1"Etc if they are not needed
Alan
I seem to be doing okay with metric.....
Metric apart from the 7/16" UNF suspension bolts which are 5/8" AF. A couple of other sizes are different and maybe imperial like the track rod ends and ball joints. Mainly metric but also depends on your engine suspect metric again.
Bob :)
I have an unused set of AF spanners
If you buy metric in 1mm increments that will do, 16mm is for suspension
My set is 6mm-19mm +22mm its rzre I use my old set of af or unf
Hi
   Is it only the front suspension bolts that are AF I already have bought metric for the other parts I did know about the rear suspension
Alan
Everything seems to be metric on my car
and what is wrong exactly with an adjustable spanner and a set of moles grips :p:laugh:
Oohhh dear, don't forget the big hammer.
... and chisel.
Get a complete set of both metric and AF spanners and always use the correct spanner/socket for the nut/bolt.
When I was a lad I was given a clip round the ear if I used the incorrect tool.
