ALANBEAL Posted January 1, 2013 Posted January 1, 2013 Hi All After not working on cars for over 30 years I now have to bite the bullet and start rebuilding the front end of my Westie.The rest will follow It may seem a very silly question but what size spanners and sockets do I need are they metric or imperial I cannot work out if they are 16mm or 5/8" some parts are OK but I want to fit new bolts etc I know I need high tensile for the suspension but where can I get them, Can I mix high tensile bolts with stainless steel nuts and washers if I can get them in self locking I may change the front anti roll as it may be bent I will post some pictures if someone can tell me how to Waiting for help Alan Quote
Geoff101 Posted January 1, 2013 Posted January 1, 2013 Hi Alan, Most of the suspension bolts are 7/16" UNF. You can buy the appropriate bolt sets from Westfield. If you ask nicely, they should do you a decent price. You'll need a 5/8 AF spanner for those bolts. Ball joint tapers are bigger but also imperial from memory. If you do a search for my content from last year, I listed all of the torque settings. I'll see if I can find the post. Lower ball joint to wishbones are m12 I think (if you have the later, two bolt lower ball joint). Quote
Geoff101 Posted January 1, 2013 Posted January 1, 2013 Here you go: http://forum.wscc.co.uk/forum/index.php/topic/89568-uprights-wishbones-and-ball-joints/ Quote
fatbaldbloke Posted January 1, 2013 Posted January 1, 2013 It's important the right strength nuts and bolts are used for suspension. Stainless is not as strong as high tensile steel. I'd be tempted, if you're not entirely sure of what you're doing to get all the parts from Westfield. You can't really go wrong then. Quote
ALANBEAL Posted January 1, 2013 Author Posted January 1, 2013 Hi Thank You all I think the new wishbones will come with all the bolts NOW ANY Idea,s on a front ARB Alan Quote
SootySport Posted January 1, 2013 Posted January 1, 2013 Hi Thank You all I think the new wishbones will come with all the bolts NOW ANY Idea,s on a front ARB Alan You'll then have to buy longer wishbone bolts as the ARB brackets need to fix on the end bolts. Try your local Fastener shop, they will have High Tensile versions. Quote
fatbaldbloke Posted January 2, 2013 Posted January 2, 2013 Some of the ARB suppliers will supply the correct bolts as part of the kit - suggest you talk to Luke at Plays Kool. Quote
NMac Posted January 2, 2013 Posted January 2, 2013 I get nuts and bolts online from Grove Components at www.groveco.co.uk They have almost anything in bolts, set screws, and so on in high tensile steel and stainless steel, and appropriate nuts, washers, etc and provide a very rapid delivery. Quote
ALANBEAL Posted January 2, 2013 Author Posted January 2, 2013 Hi I have been comparing the ARB all ready fitted to my Westie I think it is an early Westfield one it is vee shaped in the middle to go around the electric fan it looks a bit homemade but it is very similar to the plays kool one any comments Alan Quote
