Fuel Tank!
As my family sleep around me, stuffed full of Christmas goodness, I was thinking about fuel tanks.
What's the safest set up for the fuel tank? Can you get a foam filled tank that would slow the release of fuel if the tank took a hit?
Merry Christmas all!!
If it took a hit and wouldn't release the fuel then how would it release the fuel to get to the engine?  Whoops!!!
The idea behind foam filling is to stop the fuel sloshing around to quickly when going round a corner therefore stoping the weight of the fuel upsetting the cars weight distrubution.
Terry
Bag tanks are probably more what you're thinking of. But on a non competition car it might not be a first, but I bet there are very, very, few other Westfield's out there.
If you're particularly worried about road debris puncturing a tank, fit a diffuser or make a panel to go under the tank.
In an accident I think I want my tank to puncture and p*** all the fuel away. That way it's not all in the same place waiting for a big enough spark, or being pumped all over the engine bay by a shorted out fuel pump and a broken inertia switch...
The aerorace kits for competition have the fuel tanks installed above the diff much the same as the FW tank rather than behind it so as to reduce the risk of damage to the fuel tank in event of a rear hit.
  • 2 weeks later...
  • 4 weeks later...
I'm not sure if a locost tank will fit but the same company also make a one designed specifically for Narrow bodied westfields
http://www.alloyracingfabrications.com/westfield-alloy-narrow-fuel-tank-6-5-gallon.html
On new tanks they can also customise them to your needs such as by adding a sump, and I'm sure if width is an issue they could make one a bit narrower than standard.
http://www.alloyracingfabrications.com/sump.html
:t-up:
That tank looks very similar to what I already have, maybe I'll measure my one up and ask them to price one up slightly narrower
Why not ask if the can shorten it.
