Messaihs Or Are Red Bull Just Very Naughty Boys
hmm, wonder how this will pan out, as it does appear to be made of some flexible material, which would be against the regs.....
Ooooh Naughty!!!!
I agree initially it looks very naughty, but what do the other cars look like on the same corner? Also it'll be hard to prove as they must have passed the FIA bodywork testing before the race. ???
Very clever idea I would say :yes:
Hopefully it will lead to a complete ban on all those silly appendages . :oops:
Realistically every other team will now be sat at there drawing boards ;)
i would imagine the rest of the teams knew about this anyway
I was more concerned with the logo on the nose cone and then the image of the man crouching over it in the 1st pic :d
evident last year but apparently passes fia testing
The nose cone could be engineered to be flexible in one direction, upwards. A mechanical link could be engineered between the upward deflected nose cone and the wing such that the angle of attack of the front wing was reduced thus reducing induced drag.
When is induced drag greatest? - at high speed
When would an aerodynamic bending force on the nose cone be greatest - at high speed
When is an F1 car at highest speeds? - on the straights
When is downforce least needed? - on the straights
How do the FIA test for flexible front wings? - with a static load acting to bend the front wing downwards, force is 1Kn, deflection permitted 10mm at wing tip
What do the regulations say? - Front wings (and all other bodywork) must be rigid, movable aerodynamic devices anywhere are illegal
As Ferrari's 2007 flexi-floor, this is likely a deliberately designed & engineered method to break the regulations while passing the test that is supposed to prove legality.
No different from Balco designing performance enhancing drugs which cannot be detected by drug tests
If that's what it does It's not clever, nor genius, just cheating
If the nose drops at speed to help downforce when cornering it will then cause a negative affect by reducing top end speed on straights so is it really an advantage?
I think it's designed to reduce drag at high speed, the angle of the wing becomes more horizontal as force increases, because the nose twists?
ive got that on my westfield.... gives me a noticeable advantage between 30 and 65.... on the way to get the papers.... interesting imagery though and interesting that it passes the regs... Cheers
As far as I can tell the load testing is vertically downwards at the end of the wing? So that only tests deflection in that plane, rather than any twisting, and therefore the wing passes the tests.
Mr Newey is a clever man - I think a few of the other teams may have copied the design too, remember seeing an article somewhere that seemed to show McLaren had the same 'rotation'.
What is odd is how the yellow part of the nose deforms during that pit stop though! Seems to contravene Charlie's statement in the first post...
perhaps the mechanic had 4 weetabix that morning :p
Do you see how the mirror stems appear to be flexing, maybe that is cheating as well....
Let's knock anybody that's good at what they do. That's what distinguishes the British from most other countries.
