Replacing Nylon Bushes In Upper Steering Column
Morning all.
Yes I've done a search but not comeup with a definitive answer. The problem is that there is quite a bit of movement between the shaft and the upper steering column. I will be fetching it out of the Westy so I can have a go at replacing the nylon bushes with two that I've got from the factory. My column has a detachable wheel and an additional sleeve on the column at the top - in other words the shaft will only come out from the top.
So what do I do next??
Your thoughts and advice eagerly awaited.
Thanks - Rory's Dad
Did mine at the beginning of the year and i managed to get it out as i wiggled the column out
Otherwise remove the column and break it up with a small chisel and push it out through the bottom
So,if I pull the column out, will the old bushes be on the column or still inside the tube?? Obviously I'll replace them sliding them up from the bottom. Is there some sort of seating for them?? Will they need any lubrication??
Rory's Dad
Last time I removed my inner column, it just slid out, leaving the bushes behind. It had been coated pretty liberally with Copperslip when manufactured, so after it came back from welding, I re Copperslip'd it and slotted it back in.
Right chaps, it's all in bits and the new bushes are too bloomin' big :angry: :angry: :angry: .
The dimensions are (more or less) as follows:
Inner column = 20.00mm diameter
Outer column inside bush = 20.04mm diameter (so 0.04mm of slop)
Outer column outside bush = 24.78mm diameter
so the existing bush thickness is 24.78 - 20.04 = 4.38/2 = 2.19mm
The new bush is 20.30mm inside diameter
and 25.25mm outside diameter
so the new bush thickness is 25.25 - 20.30 = 4.95/2 = 2.47mm
So there is 4.95 - 4.38 = 0.57mm difference in bore.
My question is - would it be feasible to cut through the new bushes, squeeze them into the outer column and re-assemble??
Thanks - Rory's Dad
Don't see why not!
Dont like the sound of that
can you not get some new nylon material reamed and lathed to fit exactly?
I have some spare nylon you could use
Give me a call
Dont cut them and press onto the tube,get the right bushes
The transformation was unbelievable
Mine was packed with heater hose and grease
My bushes look like a top hat with a hole and so have a lip to seat in place
What column have you got fitted
Thanks Steve - I think it's an Allegro column (I think I have a BL key somewhere)..
I'll give Terry a call about getting some new ones made.
Rory's Dad
