Chaps,
Just trying to search for some info and I was shocked (shocked, I tell you) to discover that the search requires a minimum of 3 letters in any words. Makes looking for V8 ............ a bit of a bind...
Can that be altered?
had the same experience when searching for the word "sex" in here
went onto google and hey presto the world was my oyster ;-)
I have the same problem with SDV and MX5 :down: no problems with Sex though :d
Raised that when we had the change over, originally it was a four letter minimum! We got it reduced to three, but it's such a PTA, I still regularly just do a Google site specific search instead. :down:
Cam
XE
SBD
QED
16V
TPS
CPS
ARB
CRB
red
The list sort of goes on...
The trouble is if your search string includes just one term, the whole string is rejected.
That said you can sometimes get away with it if you add a wild card - cam - fails, but - cam* - will work and return results that include cam, cams, camshaft etc.
For Smokey - mx5* works too! ;)
"MBE ECU" caused me issues! :cry:
Excellent :t-up: thanks :)
P.s. you listed 16V twice :d
No i didn't :p
:blush: :blush: :blush:
:d
Chaps,
Have you done a search?
Aaaaaahhhhhh...man, that felt SOOOOOOO good! :cool::laugh::p
Dropping it to two letters would be a nonsense, you'd get tons of crud back. Imagine if you type in "ca" - you'd get from cab to caw, with cat, cab, can, and cap thrown in.
I never thought i'd see the day when Blatman couldn't do a search :oops:
Sarcastic reply self censored. (For being an :arse: )
Please don't berate a reasonable request so flippantly. The fact that the search module may be poor, or the indexing places too much demand on the hardware or software is rather more the issue. if that's the case, or some variation of it, then so be it, we'll have to live with it.
Gadgers, I wasn't trying to berate it, sorry if it came over that way, certainly not my intention to do so, just stating my opinion is all, which I hope I'm still allowed. It's already been reduced from 4 to 3, if people only put in two letters, I can see it turning something an awful lot better than the old boardroom one into something useless.
However, in the spirit of things, for a day or two, I'll reduce it to 2 letters to see how it gets on - but don't blame me if it produces garbage.
Give me 20 minutes.
EDIT: OK, changing that to 2 letters didn't work at all.
So I switched "Use fulltext searching" from "Yes" to "No" - now, I have no idea what the devil that means at all, but...it does seem to have worked, and you can now search two letter strings. Don't ask me why, you just can...
Note as well that only the last 300 posts or topics in the last 365 days are shown, unless you use the Advanced Search button.
If two letters throws up too many anomalies and there are too many complaints, we'll have to look at ramping it back up to 3 letters.
Wasn't having a go Scott honest, but it's been deeply frustrating, if it's a limitation we're stuck with, and we know why, then there are work arounds.
Frankly though, as I've alluded to in, er, other threads, that we won't rehash here! I don't think the search function gets used as much or as finely, as a lot think it does!
The trouble is, technology and engineering is such an acronym filled world, that even without three letter names, it's still very difficult to drill down to what you want without being able to use at least three characters.
Does the search engine not have an internal "ignore" list? (That prevents it trying to index and return hits for basic grammatical terms, or, and, the, its, etc)
I know I give off an air of slight intelligence on the odd occasion Dave, but f me if I know if it has an internal ignore list. Sorry.
I do know that two letter searches like V8 and three letter ones like MX5 do work now, so give it a bash and see what you think.
I can't remember if it's a general term, or just the name used by the last "search engine for dummies" :blush::oops: type software I set up. Basically a sort of list of words that the search engine ignores. Typically includes a lot of grammatical "padding" along with terms that are so frequently used as to be useless for searching.
I think so. If you search for "the" and "it" you get far fewer results than you'd expect.
