A post in the techie talk forum should reveal the plug size,
As for bolts, I have a load in the garage that might be of use, you are more than welcome to drop over and see what we have......
  • Replies 56
  • Conehead
    16
  • Mat Jackson
    12
  • limee
    9
  • Lestaz0
    7
Great cheers mate, I got a 3/8 radiator plug which seems to work so just need a few unf bolts. Oh also i just checked and it started first time, seems a bit too good to be true!!!
Posted (edited)
Well you'll all be glad to know its done it again!!! The oil hose sheared off on the m4 today luckily is sunny while I'm now sat on the side of the motorway.
Also I managed to kill the engoine before it did any damage phew!
Edited by Conehead
Will be interesting to know why but bad luck anyway lets hope nothing terminal this time.
Bob :(
After the AA's priority pickup off the side of the M4 which took 2.5 hrs I have had time to inspect the damage through all the oil. Oil bloomin everywhere as it seems the hose had split just underneath the outlet from the oil filter. Luckily I still had oil in the car so have managed to avoid damaging the engine. I am wondering if the hose is the right spec for oil as it is much softer than the others and seems to be very pliable when hot. I do recall that it had been loosening its self recently and I have been tightening it up. I think the rubber had warped and left very little between the clip and the joint causing it to break.
I will be taking the fittings to Pirtek tomorrow morning to get them to make a proper hose up so should still be good for Wednesday.
I would include all oil hoses in your replacement regime, just in case.
Bob
There we go up and running again :d
First question then guys - can anyone bring a good dose of some serious quality engine cleaner as the whole car is covered in oil, and my helmet, RAC roll bar, I mean everything.....
Mess
Oven cleaner is a good degreaser apparently!
Paul,
There wil be no helemt polishing going on tomorrow............
Mat what do we reckon with the weather for tomorrow will you post if its on or not?.
If its on whats the earliest everyone can make it to make the most of the evening?
Ill post out an e-mail tonight with a weather update and see how many are comming.
I cant get there earlier than 7:30, I need to get the kids in bed first...
OK,
Weather is looking good at the moment - and should be good this evening too!!!
See you all at the pub at 7:30 - with the aim to leave pretty much at that time.
See you then
Mat
Going to have to dip out on tonight, you guys have a blast!
16.30 Weathers changed in Usk,absolutly Pi**ing down !!
not looking good.
Les
I drove past the otter on my why home from work and it was ok. I think its pretty changeable.
