Blatman Posted June 5, 2012 Posted June 5, 2012 According to the destructions, only .jpg images are supported, so lets start there... The Multimedia browser lets you display pictures and/or movies or play audio files stored on a USB device or a memory card. The Multimedia browser application is invoked from the main menu. Your TV is also equipped with the possibility to connect your computer or home network and to access and view your personal multimedia files. See the supplied separate Connected Planet guide for further explanation of this functionality. - Following types of memory cards can be read: Compact flash I & II, Memory stick, memory stick PRO, SD Card/Mini SD Card, Smart Media, Micro Drive, MultiMedia Card. - Following file formats can be reproduced: for pictures: JPEG for audio: MP3, MP3 Pro, LPCM for video: MPEG1, MPEG2, MPEG4, DIVX4,5 and XVID files - Only FAT/DOS-formatted memory devices are supported. - If your digital camera is not supported, try one of the following solutions: - make sure your camera is switched on and verify if its configuration settings are correct (see the manual of your camera) - remove the memory card from your camera and insert it in the memory card slot. Refer to www.philips.com/support for more information. - Philips can not be held responsible if your USB device is not supported. To insert a Memory card/USB device Insert a memory card in one of the cardslots at the right side of the TV. Insert it to be clicked in. In case of a USB-memory stick or a digital camera, connect it to one of the USB 2.0 connectors at the side. See To make video and audio connections, Side panel overview, p. 47. When a USB device is inserted, the Multimedia browser menu is displayed automatically. Don't worry about the bit that says only FAT/DOS formated devices are supported. USB sticks are almost always formatted in FAT32. Quote
