Rory's Dad Posted May 11, 2012 Posted May 11, 2012 The pipe for my windscreen washer goes under the panel over the gearbox, up inside the scuttle and connects to the washer nozzle. This needs to be disconnected when I take the scuttle off. At the moment I have a straight connector about 3" down from the nozzle. I can pull a hose off (and put it back on again) with some difficulty but I'd like something easier. Something like those Hozelock fittings for garden hose but for 4.7mm tubing would be just the job but I can't find one to buy anywhere. Aletrnatively I could re-route the hose out of the front of the scuttle with a bulkhead connector and then route it down through the panel. At least I could get at it easily. Anyone got any ideas?? Thanks for your thoughts in advance. Rory's Dad. Quote
Dibby Posted May 11, 2012 Posted May 11, 2012 If you have a windscreen you have to have washers for the IVA, is this a requirement for the MOT too? Can you just take them off? To be honest, windscreen washers on a Westfield are as useful as a dangler flavoured lollypop Quote
Rory's Dad Posted May 11, 2012 Author Posted May 11, 2012 ... but I commute on sometimes dirty roads! Rory's Dad Quote
Dibby Posted May 11, 2012 Posted May 11, 2012 You let your car get dirty. Right, that's it! Hand over the keys! Something like this? http://www.mx5parts.co.uk/screen-wash-straight-connector-p-791.html?utm_source=google&utm_medium=googleshopping&utm_campaign=googlebase So you can pull the tubing apart? Quote
Geoff101 Posted May 11, 2012 Posted May 11, 2012 I know on quite a lot of motorbikes, they fit self sealing quick release connectors to the fuel pipe from the tank. Might be a bit big for what you want but could be worth a look. Quote
Rory's Dad Posted May 11, 2012 Author Posted May 11, 2012 Something like this? http://www.mx5parts....aign=googlebase So you can pull the tubing apart? I've got something like that already but it's tucked up inside the scuttle and difficult (for me anyway) to push together properly. It's a tight fit. As I say I would like something that clicks together easily like the garden hose jobbies but for 4.7mm tubing not hose pipe. Rory's Dad Quote
zvezdochka Posted May 16, 2012 Posted May 16, 2012 Just a thought - tubing is similar size to fish tank air pumps ? http://www.discountleisureproducts.co.uk/Aquarium_Airline_and_Accessories/Pond_Aquarium_Airline_Straight_Connector Quote
Rory's Dad Posted May 16, 2012 Author Posted May 16, 2012 Great minds think alike. Called into an aquarium place yesterday but no luck. I think I'm just going to extend the tubing so I can get at it without having to turn myself the wrong way round and inside out. Just need to make sure that it doesn't squirt water over the ecu and all the rest of the wiring!! Thanks chaps - Rory's Dad Quote
Geoff101 Posted May 16, 2012 Posted May 16, 2012 If you look at external aquarium filters (that live outside the tank) they have watertight quick release connectors on but they are a fair bit bigger bore than you're looking for. Quote
Joeb_444 Posted May 20, 2012 Posted May 20, 2012 Don't know if suitable or whether the sizes are available but take a look at festo fittings you may be able to do something with those I used to run kerosene through them without problem so water should be a doddle. Paul. Quote
Rory's Dad Posted May 20, 2012 Author Posted May 20, 2012 Found this on the Festo site: http://www.wired.co.uk/news/archive/2012-04/23/festo-flying-shape - just brilliant geometry apart from everything else!! Rory's Dad Quote
