Narrow Bodied Sei Rear Suspension Torque Settings
Hi Guys,
Trying to find the Torque setting for the 3 bolts that attach everthing to the Rear Alloy Hub Carrier
1) Bottom Damper mount to Top of Alloy Hub Carrier
2) Wishbone to Bottom of Alloy Hub Carrier (Front)
3) Wishbone Rose joint to Bottom of Alloy Hub Carrier (Rear)
Unable to find in Manual, or on line
All Bolts are 7/16 UNF, and suspension is now settled, ready for final torquing
Thanks in anticipation...
Tony
I did mine the same as the front wishbone mountings and inner rears which are 28 ft/lbs
Haven't fallen off yet but would also be interested to know. If you call Russ at Westfield parts, he can usually tell you.
Geoff
Thanks Geoff,
i'll set them at 28 until I get a definitive setting
Tony
The Narrow build manual never contained anything as useful as torque settings, however the current build manual gives the following settings:
Wishbone securing bolts to chassis - 7/16" UNF - 40Nm
Lower Ball joint securing bolts to wishbone - M10x1.5 - 34Nm
Lower Ball joint nut to Upright - 1/2" UNF - 34Nm
Top ball joint nut to upright - M12x1.5 - 34Nm
Shock absorber to chassis mounting bolts - 7/16"UNF - 40Nm
:t-up:
