How Wide? How Narrow? Will It Fit? What's The Width Or Length?
Mark (smokey mow)
On 18/01/2015 at 09:03, Ian Podmore said:
Does the length include a spare wheel on the back?
Had the spare wheel taken off to make the car shorter overall and like the smoother look to the rear!
On 09/08/2019 at 18:44, stephenh said:
From what you say about your size, forget about narrow body cars.
I don't know when the wide body was first introduced, but someone will be along soon to say if it was before 1992.
Link to comment
On 06/03/2012 at 21:43, Mark (smokey mow) said:
Every so often a question gets asked on the Boardroom about the measurements of Westfield’s such as will it fit in my garage or how wide is the interior. So here as suggested by Captain Colonial I have attempted to pool all the information from past posts (and with a few dimensions from my own cars) to create a singe FAQ that hopefully will answer the most commonly asked dimensional questions. Please feel free to add anything of your own, correct any errors or suggest additional titles :t-up:
* disclaimer - all dimensions are approximate and are published for guidance purposes only. No allowances have been made to take account of different wheel offsets, interior trim panels, carpets or variations in manufacturing and/or assembly tolerances etc. It is always recommended that accurate measurements are taken from your own car before making any purchases or financial outlay.
Will it fit in my garage?
Standard Wide Body & Mazda SDV
Width (Front) over wheels/tyres (standard track) - 1480mm
Width (Rear) over wheels/tyres - 1620mm
Maximum Width over body - 1640mm
Wheelbase - 2325mm
Overall Length - 3450mm
Narrow Body
Width (Front) over wheels/tyres - ???mm
Width (Rear) over wheels/tyres - 1520mm
Maximum Width over body - 1560mm
Wheelbase - 2335mm
Overall Length - 3540mm
Sierra SDV & Cars With Extra Wide Rear Arches
Width (Front) over wheels/tyres - 1480mm
Width (Rear) over wheels/tyres - 1700mm
Maximum Width over body - - 1720mm
Wheelbase - 2325mm
What’s the smallest trailer a Westfield will fit on?
Bed length - 10’ / 3048mm
Width - For ease of loading I would recommend 3-4” / 75-100mm wider than the width across the wheels.
I want to change my seats, how wide is the cockpit?
Standard Wide Body, Sierra & Mazda SDV’s
Drivers Side - 16.75” / 425mm
Passenger Side (Wide Tunnel) - 16.25” / 410mm
Passenger Side (Narrow Tunnel) - 16.75” / 425mm
Total Interior Width - 39.5” / 1005mm
Transmission Tunnel (Wide Tunnel) - 6.5” / 165mm
Transmission Tunnel (Narrow Tunnel) - 6.0” / 150mm
Narrow Body
Drivers Side - 15.5” / 395mm
Passenger Side - 15.5” / 395mm
Total Interior Width - 36.5” / 930mm
Transmission Tunnel - 5.5” / 140mm
How much room is there in the engine bay?
Height from underside of chassis to top chassis rail - 11” / 325mm
Width of Transmission Tunnel Opening (Type9 Tunnel) - 9” / 229mm
Width of Transmission Tunnel Opening (MT75 Tunnel) - 14” / 355mm
Height from chassis rail to underside of bonnet at nose (Kit, ZK and V8 Bonnets) - 8.5” / 215mm
Narrow Body
Width of Transmission Tunnel Opening - 9” / 229mm
Height from chassis rail to underside of bonnet at nose (Low Line) - 6.5” / 165mm
Height from chassis rail to underside of bonnet at nose (High Line) - 8.5” / 215mm
I need to collect a tub/chassis will it fit in my Van
Wide body
Width of detachable arch tub without arches - 1160mm
Width of fixed arch tub - 1640mm
Length of wide body tub - 2850mm
Width of bare chassis - 41.5" / 1054mm
Length of bare chassis 2990mm
Narrow Body
Width of tub - 1560mm
Length of tub - ???mm
Width of bare chassis - 38.5" / 980mm
Length of bare chassis (to tip of nose cone tab) - 2970mm
Thanks for all these dimensions…cheers Mark 🙂
Link to comment
