Cooling Pipes + Parts
I am planning converting over to a polo rad so looking for the following:
- Polo mounting bracket.
- Lightweight Fan
- Fan mounting bracket.
- 32mm alloy pipe
- 32mm pipe with 15mm take off for header tank/heater
- 22mm blanking plug for thermostat hole in radiator.
For the fan mounting i used some 20mm flat ali bar from B&Q for about 2 quid. and had loads left.
Richard
Now sorted:
- Polo mounting bracket. = Great Tip from cleowuss, Cheers :yes:
- Lightweight Fan = ebay Pacet from just up the road.
- Fan mounting bracket. = Great Tip from cleowuss, Cheers :yes:
- 32mm alloy pipe = ebay £7 (32mm OD x 300mm with swaged ends)
- 32mm pipe with 15mm take off for header tank/heater = Westfield item
- 22mm blanking plug for thermostat hole in radiator. = Westfield item
