1800 Zetec Engine Questions
I bought the Magnatec on the basis that it was fully synthetic
I boughy Castrol Magnatec but not at that price!
I bought the 5/30 A1 as it's fully synthetic and 'recommended by Ford'
That's the one I got, it says on the front that it's recommended by ford.
I thought the price was pretty good at £21 per 4 litre can including VAT?
I payed £30 at Halfords.....
If the car is going to be used wholey or mainly on track, you may find the oil pressure drops quite a bit when it gets hot. If so, use a thicker oil. Some use a 10W-60. Try the 5W-40, and see what happens. If you find the oil pressure drops too much when hot, then try a thicker one. Main thing is if you are doing a lot of track use, use a good quality oil, and change it regularly/frequently.
  • 2 months later...
I bought a HOF241 and found out as soon as I got home that it wouldn't fit. I too it back and changed it for a Champion C104.
I'll be changing the oil this weekend.
