Megablade Honda Fireblade Engine Oil
Hi,
I've recently purchased a Megablade for trackday use and the occasional (dry, sunny day) road use. The engine is the Honda Fireblade and the previous owner used semi- synthetic Maxima oil as this is apparently very good for clutch longevity. It is however not widely available.
What do other Megablade owners use?
What are the pros & cons of fully synthetic vs semi- synthetic oil?
TIA Hadrian
  • Replies 30
  • GreigM
    7
  • nickw2000
    6
  • Dave the Sparky
    5
  • Johnson
    4
I picked my Megablade up last week and would like to see the comments on this for info too
Paul
Me too please this will be appreciated I will be watching replies
I believe 10/40 semi with wet clutch anti slip additive, I'll get the name of the stuff my m8 sells, I'm no mechanic so only repeating what he recommended, I await the flames if he/I'm wrong...
Dave
Just purchased 9 litres (damn you dry sump :cry: ) of the same oil today for my Busa not from Opie though :d
Where are you getting it from? Opie prices really aren't very good - can beat them on ebay!
What's the capacity of oil needed for the fireblade?
I was lazy and called into a Suzuki dealer I happened to be passing today I know I could have got it cheaper elsewhere but wanted it today. I have used Motul 7100 being unemployed for 3 months put a stop to buying that again :o .
Pretty sure you will get away with 4/5 litres for a Blade engined car :)
i always used 10/40 semi castrol power 1 in my blade, and using it in the blackbird lump now
ive used Castrol, Motul, and cheap **** from the local motor factors in my 1000rr sprint car with no ill effects, to engine or clutch. I just change the cheap one more often but as I can buy three for the price of one Motul its not a problem.
Mite sound a stupid question but I'm new to BEC
But do you fill and topup oil from unscrewing the dipstick with a funnel?
Connected question, there is no dipstick under my filler cap and can see no viewing glass so how do you check your level?
Dave
Here is a link to the CBR900RR service manual.
http://www.manualedereparatie.info/manuale/honda/Honda_CBR_900_RR_1996_1998_Manual_de_reparatie_www.manualedereparatie.info.zip
It gives the oil capacity and shows the sight glass as well. I don't own a Blade engined car so I am not sure if they have a modified sump or oil cooler but the repair manual states 3.6 litres inc filter :)
So whats the crack then? Im thinking this is a collection tank? but it doesnt seem to go anywhere, also as above how does one check ones level?
Dave
