Translogic Powershifter - Sold
SOLD
I had this Translogic Powershifter fitted and working on my XTR2 with Hayabusa engine before I swapped to a Proshift system.
It isn't the latest design but worked fine as a Powershifter either using buttons to shift gear or paddles (see my other advert). I'm not sure why but while the Powershifter continued to work fine (ie. it operated the gear change fine) the quickshift ignition kill function stopped working (ie. it no longer killed the ignition to allow full throttle up changes). I think it was probably either a wireing or switch problem, but I didn't get round to investigating before I swapped to the Proshift as it still worked fine without the flatshift function.
I've got to be honest, its not as fast as the Proshift and doesn't offer as many functions, but as a simple powershifter it worked fine. The wiring would take a little sorting out as the cables are now just flying ends as were integrated into my wireing loom so had to be cut to remove the unit, but the cable between ECU and Shifter is intact, and the others just need extending to power and ignition.
I'm pretty sure I have a manual for it too somewhere.
Anyone interested pleae PM me.
Thanks,
Phill.
SOLD
Bump before I put it on ebay at the weekend.
Should say too that the actuator has recently been back to Transloigic for a service and is working fine.
