RichP Posted February 15, 2012 Posted February 15, 2012 For sale is my blue 1994 SEiW on a Q plate, details as follows. Reason for Sale The car has been sat unused for some time now – well over 2 years. I won’t have the time to look at it this year and honestly I’ve had enough of seeing it sat in the garage in an incomplete state. I’d rather someone put it back together and made some use of it. I’ve spent quite a lot on it since I bought it – the spec is below which I think makes it quite a lot of car for the money. If you’ve the time and a little money to spend through the rest of the winter you could easily have a car on the road for spring this year. Any inspection is welcome – I’m located in Stevington, Bedfordshire. You can contact me on 07809548743 or email me at richparsonsemail@yahoo.co.uk Price: £3750 ono If you think this is too high then make me a reasonable offer. Work I think it needs to get it back on the road: Wiring in the front of the car (mostly dash area) needs work to complete and re-connect. This is the main area of effort. I have the original build manual and wiring diagram to assist with this. Dash & clocks (can supply most of this to get you going but you might want to upgrade as what I have is dated) Gearbox + lever extension (nothing supplied with car) Some small ally tunnel panels (easy jobs) Front lower wishbones need new powder coat Connect the engine wiring back up (engine is just sitting in the bay and will need bracing to move the car – no big deal) Good check over to make sure all is well MOT etc Engine Ford x-flow 1700cc Kent 234 cam, offset dowled Twin 40 DCOE Webbers ITG Filter Megajolt ignition, mapped by NMS 15 May ‘09 Brakes FR M16 calipers with Mintex M1144 pads. Rally Design grooved & drilled disks RR Sierra callipers with Mintex M1144 pads. Standard disks FR Suspension Procomp Motorsport widetrack wishbones with Polybushes Protech shocks valved by Procomp and matched in pairs 400lb springs RR Suspension Independent wishbones with CAT Motorsport nylon bushes Protech shocks valved by Procomp and matched in pairs 180lb springs Gearbox None Differential Sierra 7”, viscous LSD, 3.62 ratio (supplied separately - not currently fitted to car). Other stuff - New fibreglass shell seats - New 6 point 3” Sabelt harnesses - Carbon bits n bobs – aeroscreen, arch protectors, sill protectors, boot cover - Braced roll bar (used to be call “RAC” but no longer MSA approved) - Lightweight gel race battery - Simpson stainless silencer Pictures Please see here: http://www.flickr.com/photos/34566091@N02/sets/72157627795231268/
Martin Keene Posted February 15, 2012 Posted February 15, 2012 Wow... Cheap project car for somebody. 1
Johnson Posted February 15, 2012 Posted February 15, 2012 Blimey bargain of the century Shame I am skint
Geoff101 Posted February 16, 2012 Posted February 16, 2012 Let me know if you need a home for that x/flow megajolt Steve!!
