What Would You Expect To Pay For Engine/box In And Out?
I recon to get that time they have looked on autodata or similar for teh mechnic time to swap an engine on a normal saloon by the book.
I can get my BDR out in about 2 hours. It's easier due to the "through the bonnet" manifold so only one pipe to remove rather than 16 manifold nuts some of which can't even be seen.
About the same time to refit if I was in a hurry but I always seem to take all day as I clean this, move that and generally play about.
£900................ there taking the p***.... however if you didn't get an estimate/quote B4 hand then not sure where you stand???
Best start learning how to do these jobs yourself, £900 will buy you a lot of tools.
Seems very long time to me!!!!!
They might have managed it quicker if they'd have gone for a 4 door car rather than a 2 :oops::d
It all depends on what you asked/agreed the mechanic to do and at what rate of charges per hour plus any parts. My view is that £900 seems very excessive for just an engine and box out and in. But is that all that was done. If there is other work involved that should have been made patently clear and understood. You may have been ripped off or you may have been charged correctly for a work content you may not have fully been aware of.
It may have been adviseable to have an agreed estimate before the job started to avoid any such issues. But thats easily stated after the event. A detailed bill and breakdown of charges will clear that up.
Bob
I must be slightly slower than Terry, I'd say three hours out and four back in for my dura/quaiffe setup.
£900 does sound rather costly, not many indie workshops are charging more than £50-60 an hour round my way and there are plenty that are more like £40; dealers cost more obviously but I assume you didn't give this job to those guys!
Dont think I would employ that lot :d
I would get smokey to do it' he does it proper in a minute and a half according to his video and even at £200 PH it would still be cheap ;):laugh:
let us know how you get on................... if they can explain all the time spent then you may be stuck with the bill...............
We did a clutch on a Tiger a couple of years ago which was box in and out as well as an MOT at the same time. This needed the engine and box to be removed and refitted to do the job. The whole job only came in at just over £300.00
Without knowing their actual hours worked & rate, plus an itemisation of what was done, it's all a bit idle speculation really; yes, on the face of it, it does sound a lot. I know, pre dry sump, and when the alternator was on the exhaust side, I used to be able to remove my engine, then 'box in about 1 hr 40. (I'd had a lot of practice at that point :blush:) back in, dressing cables etc took longer, probably a good two and a half to three hours, except once, when the engine just wouldn't line up on the box, which took much longer.
HOWEVER, the time I foolishly ;) listened to all the advice telling me to refit engine and box as one unit was an absolute nightmare. Ending up taking six hours, and involving me steadily stripping more and more off the car and engine to get them to fit past the tunnel hoop and clear the top scuttle rail. (Yes, I know others manage fine, but without cutting my hoop off, mine doesn't, though the hoop is, er, somewhat lower profiled than the factory intended :blush: )
