Surplus Bits & Pieces
Updated 26/2
Too much stuff taking up space, so:
Cycle wing stays - pair for cortina uprights, need paint but good. £SOLD
WF cycle wings - pair, standard width up to 205 max, painted blue, no bolt holes, vgc. £70
WF cycle wings - pair, wider ones in yellow gelcoat, drilled with slight crack around one hole. gc. £60
Rear arches - pair, painted blue in gc. £100
Driveshafts (lobro) - pair, Sierra diff (7"), mucky but vgc. £160
AVO rear shocks+springs - pair, rosejoints, 345mm c2c, not alloy. gc. £SOLD
Windscreen fillet - early widebody, suit early w/screen pillars, blue. £SOLD
Lights - fog £10, reverse £10, n/s rear cluster £10, all rectangular.
Bootbox - red, widebody. £SOLD
Handbrake lever, mech & cable - for Sierra calipers. gc. £35
Custom wiring loom - Includes fusebox, connections for Stack dash & Emerald ECU for XE engine on TB's. Not tagged and needs tidying but mostly complete. Wiring diags included (if I can find them). £SOLD
Innovate wideband lambda sensor - connector damaged, includes box & setup disc, untested since removed. £SOLD
WF Heated windscreen wiring loom - new, unused. Plugs into standard WF loom. £SOLD
PM me your email for photos and further info. Collect in person or plus P&P from central Scotland.
If you can't PM, mattdotalexanderatvirgindotnet should do the trick.
Cheers,
Matt
You have PM :)
You have PM :)
PM replied to :)
You have PM.
pm enquiry sent ref cycle wing stays
PM sent
All PM's replied to (I think!)
Matt
List updated with what's available.
Matt
Updated
Matt
Updated
